Previous in Forum: Electrical Design Engineer   Next in Forum: Diffe. Between Solar Panels V/S Building Integrated Photovoltaic Products
Relation of Motor Enclosure Protection with Voltage Level.
04/18/2014 2:43 AM
it is usual to use EEX d, EEX e & EEx p motors in ZOne 1 & EEX d, EEX nA & EEx pz motors in ZOne 2 same is applicable for motor terminal box.
is there any limitation or restriction of the above if the voltage level is increased.
i. e for higher voltage(6.6KV) more Stringent protection is required than lower volatge(440V) in the same zone.
Thanks in advance.
Good Answers: 181
Re: Relation of Motor Enclosure Protection with Voltage Level.
04/18/2014 9:14 AM
The motor manufacturers will give you that information, they have to certify the motors characteristics.
The question is so general as to make me think this is homework.
Good Answers: 117
04/19/2014 2:46 AM
Good question, but it is something you would know from attending a 4 week course on Ex equipment, its uses and deployment.
I would like to tell you the answer, but I'm afraid, very afraid a little knowledge in this case is EXTREMELY dangerous. You ONLY have one opportunity to get this right, and a dozen or so lines in an open forum, will not give you the level of knowledge or expertise to comprehend the answers.
I suggest you find a training course, register and attend for this type of equipment. I can tell from your questions you know very little about the topic as you've not asked about termination of cables and the use of cable glands. A full blown training course is the right way to go in this instance.
Register to Reply 2 comments
