Previous in Forum: Bentley 6.75 Turbo   Next in Forum: ASME code number for seamless (steam line) pipe
8.8 Grade Fastener?
06/14/2007 3:27 AM
what is meaning of 8.8 grade fastner ?
South Africa - Member - ShoSholoza Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member
Re: grade
06/14/2007 4:24 AM
Bolt grades that I know of are: 4.6, 5.6, 6.8, 8.8, 10.9, 12.9
The first number multiplied by 100 is the minimum tensile strength of the bolt material in MPa
The second number multiplied by 10 is the ratio of the yield stress to the minimum tensile strength
Thus a grade 8.8 bolt has a minimum tensile strength of 800 MPa and a minimum yield stress of 0.8* 800 = 640MPa
Can you imitate yourself?
Reply to Forum Thread
You might be interested in: Hook and Loop Fasteners, Captive Fasteners
