Previous in Forum: Pellets Industrial Machinery Manufacturers   Next in Forum: the design of rf field
Help! Urgent Need for Japanese Bearing Spec
06/15/2007 11:15 AM
how can i find NTN japanese spec for bearing with code no : NJ324 ECMC3 + HJ324, really needed it urgently... or any compatible brand also can!!
somebody please Help me!!!
Desperately needed in URGENT!!
Re: Help! Urgent Need for Japanese Bearing Spec
06/15/2007 11:40 PM
Did you contact the company in Mt. Prospect, IL (Chicago area) which is US HQ, or their Automotive group in Farmington Hills, MI.
06/16/2007 12:26 AM
Try FAG NJ324 E TVP2+ HJ324E
Shaft Inner ID = 120mm
Bearing outer OD = 260mm
Bearing thickness = 55mm
Internal through raduii = 3mm
Outer roller race ID = 230mm
Inner roller race OD = 150mm
Outer race roller retainer lips ID = 218.7mm
Inner race roller retainer lip [One Side only] OD = 168.1mm
Inner bearing roller retainer Angle ring extension length = 14mm
Inner bearing roller retainer Angle ring length [beyond bearing roller end] = 22.5mm
Bearing Mass = 13.5Kg
Angle ring Mass = 1 41Kg
Load Ratings dynamic C = 520kN
Load Ratings static C0 = 600kN
Limiting speed min-1 = 2800rpm
Reference speed = 2600rpm
All the above information is available on pages 290 / 291 in the FAG Rolling Bearings Catalogue WL 41 520/3 EA/91/8/01
I hope this is what you required.
Mechanical Solutions Company where 'There is no such thing as a PROBLEM, just an ISSUE requiring a SOLUTION'.
Register to Reply 2 comments
