Previous in Forum: Napkins with Drawings of Different Ancient Castles   Next in Forum: Can We Scale it Up?
Rotary Memory and Positioning
05/07/2014 5:22 PM
A shaft must be rotated to 4 alignments by positioning the shaft manually and somehow memorizing each alignment. Then pushing one of 4 buttons to rotate the shaft to the corresponding alignment. The shaft must not move if power or control signal is lost.
Re: Rotary memory and positioning
05/07/2014 5:27 PM
Connect a shaft encoder to the shaft, and a counter to the encoder. Note the number position of the readout at the desired location. Reposition to that number when required. Scale your encoder to the desired accuracy by ratio coupling the shafts. Reference all movements to the index of the encoder. Implement automatic shaft positioning by adding a stepper motor and counting encoder pulses. Scale accuracy of the stepper by ratio coupling as well. Arduino project.
05/07/2014 5:37 PM
To do this manually, all you need is a disk with 4 holes in the correct positions and a locking push button with a pin on it to engage the holes.
If electrically, micro-switches and a motor. If electronically, an encoder, control circuit and a stepper motor.
<Edit> OOPS thought I was replying to OP. LITT you must have edited your response, too.
05/07/2014 5:40 PM
Yes you are correct. As implied by the wording of the OP he wants to position manually, record or memorize the location, and then go back to the locations automatically by pushing buttons. Rudimentary CNC. Sorry, I thought you read it.
Good Answers: 183
05/08/2014 4:13 AM
Better to have an absolute encoder and programm the position after it is set by hand.
The µP will go to the programmed position. It saves the counter problem and correlated errors.
Register to Reply 4 comments
LongintheTooth (2); lyn (1); nick name (1)
