Previous in Forum: Definition of Motor Thermal Time Constant   Next in Forum: xd and xq
MR Tap Changer Control Mechanisms
05/08/2014 11:01 AM
Is it possible for me to interchange MR tap changer control mechanism boxes only from one Type: M III 350Y 170/C, 12.7 OHMS, Type: MA7 196966(DIAGRAM), 3~ 380V,50Hz, .75KW, 220V (AC)
TO this: Type : MIII 300 Y, 60/C , 12.7 OHMS, Type: MA 7 29816TS, 3~380V, 50Hz, .75KW, 110V(AC)
Both are VDE 0532, IEC 214
Pathfinder Tags: MR TAP CHANGERS
Good Answers: 445
Re: MR Tap changer control mechanisms
05/08/2014 11:36 AM
You did notice that the control circuitry contact rating in one is 110V and the other 220V? The best way to find out is to call MR in Germany.
05/08/2014 3:50 PM
We have already had one death down here recently due to an exploding tap changer, best you talk directly with the supplier.
India - Member - New Member
05/08/2014 4:06 PM
May find out difference in the ordering information section on MR web site.
http://www.reinhausen.com/desktopdefault.aspx/tabid-305/78_read-227/
When was last time you did something for first time.
Re: MR Tap Changer Control Mechanisms
05/09/2014 1:48 AM
Since you asked if its possible, My answer is NOTHING is impossible if only you know how to do it. I suggest you contact MR if you're in very much doubt otherwise no problem in interchanging the " Boxes " as long the mechanism fits and can the mounted properly ... as for the voltages being different it doesnt really matter since you're just dealing with "BOXES" only
" Mukutsvaga Kurarama, Vana vevhu vatekeshera pasi rose " by Me
"Everything you can imagine is real."
"Do not follow where the path may lead. Go instead where there is no path and leave a trail."
Register to Reply 4 comments
Happy singh (1); jack of all trades (1); Kudzanai (1); RAMConsult (1)
