We need a lot more information about the what the needs are to provide advice on the application. Things like the environment, the I/O, the HMI requirements, the process, etc.
That being said, what do you mean by "designing a SCADA"?
"You can't stop a bird from landing on your head, but you can keep it from building a nest there.".....Mom
"SCADA" Supervisory Control and Data Acquisition (for those of you that are not familiar with the term)
Do you mean "Power Line Carrier" for the communication link by the second PLC term?
There are some important things that you need to keep in mind in the designing or spec-ing this system
1. Do you need telemetering ?
2. What transducers are available or need to be installed?
3. What degree of security is required and what are the consequences of a fail to operate or a false operation?
4. If security is high, you will need to consider a two operation code system, confirm selection BEFORE OPERATE before sending the operational codes.
5 You also will need axillary switches or process sensors on each device supervised to report its condition or position.
Your project can be quite extensive. I have specified about 30 systems (older design, some with mechanical relays), however, my field experience is limited to power control and not process control.
I suggest you use these comments as a guide for writing the specifications for your system. To design and build it completely by your self opens the door for many pitfalls.
There are dozens of manufactures available with systems that range from just remote indication to complex control Nuclear plant control systems.
Uh, this isn't really designing a SCADA (system). It seems you are describing polling data with a PC from a PLC and trending the information using NI software.
You refer to the PCU address. How will the PC be connected? Direct serial, Modbus, ethernet, etc.? Are you asking about the register or data location in the PLC?
