Previous in Forum: Inverter   Next in Forum: Load on Transformer
Good Answers: 170
Transformer Rating Vis-A-Vis Voltage Ratio
05/14/2014 6:31 AM
Is there Standard specifying typical capacities of transformers in each voltage ratio, say, 11kV/433V, 22kV/433V, 33kV/433V, 33kV/11kV, 66kV/11kV, etc. Or is there a sealing maximum capacity in each voltage ratio? And, the answers may please be referred back to some National/International Standards.
Location: KCM, chingola; copperbelt; zambia; southern africa.
Re: Transformer rating vis-a-vis Voltage Ratio
05/14/2014 6:59 AM
http://electrical-engineering-portal.com/what-is-transformer-rating-based-on
http://www.sayedsaad.com/fundmental/21_TURNS%20AND%20VOLTAGE%20RATIOS%20%20.htm
an error does'nt become a mistake if corrected!
Re: Transformer Rating vis-a-vis Voltage Ratio
05/15/2014 1:03 AM
Any capacity is available within any voltage ratio (within reason). Capacities are normally defined by the transformer manufacture's facilities and expertise and the voltage ratios by the supply voltages and customer's machine requirements.
05/15/2014 1:16 AM
Simplest Answer ..... NO STANDARD THAT SPECIFY THAT ....
"Do not follow where the path may lead. Go instead where there is no path and leave a trail."
Register to Reply 3 comments
beentheredonethat (1); DmanEng (1); Kudzanai (1)
