Previous in Forum: Validation for Pharmaceuticals   Next in Forum: What's Old Is Still New
9 comments
Ring Gauges and OD for Round Parts
06/21/2007 12:44 AM
I need help to know what the maximum tolerance should be on a ring gauge (GO) used to check OD of a round part. Lets say that the tolerance of the part OD goes from 4.24" to 5.24", then, is there an standard that allows a ring gauge to be greater then 5.24" ?
Re: OD ring gauges
06/21/2007 7:50 AM
from what I remember 5.24" +0.0 -10% of tolerance (ie, 5.24" to 5.14")
4.24" +10% -0.0 of tolerance (ie, 4.34" to 4.24")
Or was it 5% or mixture of the two! cant remember but I don´t think there is a standard which allows greater because it would be out of tolerance!
A pre-plate gauge would be smaller by a smidgen!
Have you looked at the ISO webpage or the BS webpage?
Re: Ring Gauges and OD for Round Parts
06/21/2007 8:11 PM
I was unable to see the ISO norm because I could not pay for the article. But I also was told that there is an International Gage Standards that talks about that tolerance that basically allows for a ring gage to be made to the maximum OD spec plus an specific number (in thousands of milimeters). Can some one send me one of those standards?
Thanks,
Good Answers: 94
06/22/2007 4:56 AM
This company http://www.ypg.co.uk/content/PageServer.asp?S=433501537&C=1252&Type=G&AID=17 has an on-line calculator which works out the gauge tolerances in accordance with BS969. They also have a chart of tolerances here http://www.ypg.co.uk/documents/Tolerance%20Chart%20BS%20969%201982.pdf
06/22/2007 6:13 AM
We use this gauge tolerance chart for all of our rings and plugs.
06/22/2007 6:36 AM
I also found this site, it may be more helpful.
06/29/2007 2:13 AM
Thanks J.C., your input is very helpful to me.
Ave.
06/22/2007 6:44 AM
When you purchase a go ring gauge it is made to a plus tolerance to the standards this is why it is a go gauge. If you were to order a no go gauge it would be made to a negative tolerance to the standards.
06/22/2007 8:18 AM
This is correct for plug gauges. A go ring gauge has the tolerance applied to the minus side ( + 0; - whatever). They are made this way so that it may fail a good part but never pass a bad part.
06/25/2007 1:15 PM
They are made with a plus tolerance to accept parts up to your specification and not above the specification. You will never ship a out of spec part because it will not fit the gauge. You can not force the material into a gauge which is smaller. Thus the saying you can not force 10 lbs. of poop in a 5 lb. hole.
Register to Reply 9 comments
Anonymous Poster (2); Ave (2); J.C. Couch (3); Mr. Truman Brain (1); Nigh (1)
You might be interested in: Metal Ring Seals, V-ring Seals, Ring Gages
