Previous in Forum: Cherry Trees   Next in Forum: Coversion of Deg C to Kilowatt
Gas Types for 33g Cylinders
05/21/2014 12:21 PM
Other than CO2 gas are their restrictions of using other gases in this 33g cylinder.
Which manufacturer would do this.
Re: Gas Types For 33g Cylinders
05/21/2014 12:23 PM
I'd check with several manufacturers and choose the best one.
Good Answers: 444
05/21/2014 12:48 PM
Apparently not, but these may be other than 33gms each, or with bayonet, not threaded necks
Good Answers: 50
05/21/2014 12:49 PM
If I understand your post right, you want to have a 33g size gas cylinder, that is intended for air pistols and rifles, but use a different gas.
Understand that these cylinders have CO2 in a liquid form, so they can provide propellant for many firings. CO2 can exist at room temperature in liquid form, and it's state is what is called saturated liquid/gas. Any other gas that would have sufficient pressure, would exist in gas form only, as nitrogen, oxygen, argon, etc. are beyond their critical temperature (unless chilled to a very cold temp). So you would have limited firings of an air gun using other gases.
Am I understanding this correctly?
ignator -
Good Answers: 266
05/21/2014 12:54 PM
Those cylinders are used for other gases. N20 and Helium being two others. The N20 are used in a whip cream dispenser.
There are laws regulating what gases can be place in them which vary from country to country.
http://www.ntg.co.jp/english/products/
Register to Reply 4 comments
ignator (1); lyn (1); ozzb (1); RAMConsult (1)
