Previous in Forum: New REE Metal Making For Aerospace Industry By JOOIL Metalcasting Institute   Next in Forum: International Conference on: Urban Planning and Architectural Design for Sustain
31 comments
Split PST Files
05/28/2014 8:16 AM
The software splits large pst file on the basis of sender's e-mail ids and date. To split pst file on the basis of date, either you need to enter the total number of months or the exact dates between which you received the e-mails. However, to split pst file on the basis of e-mail ID, you will need to select the mail-ids of the users, whose mails have to be saved into a particular PST file. The software enables the user to view messages in 3-view format, restores formatting from RTF and HTML messages and create unique profile for individual pst files. It supports MS Outlook 2000, 2002(xp), 2003 and Outlook 2007 and compatible with Windows NT4/ 2000/ XP/ 2003/ Vista. It is an easy-to-use and highly effective tool to get your precious mails back to you. The software is Simple to operate, with no prior technical skills required. It is backed up with 24X5 unlimited customer supports and 30 days money back guarantee.Company having more than 15 years of experience and thousands of satisfied clients across 137 countries.
Read More:- http://www.pcrecoverytools.com/split-pst-file-tool.html
Pathfinder Tags: pst recovery repair split tool
Re: Split PST Files
07/30/2014 7:50 AM
Instead of recommending any third-party tool here, I would like to share some manual tricks for splitting a large-sized PST file. MS Outlook supports some functions which can be used for splitting an Outlook PST file. You can use either Archive, Import and Export or Move to folders functions. If you have no idea how to use any of these functions, you can read the blog linked below:
How to break or divide an oversized PST file into multiple parts?
Read this blog.
Regards.
SanDERR
Re: Split PST Files
08/25/2015 8:54 AM
The blog post I linked above is no longer available. It has been redirected to this source: http://wordpress.semnaitik.com/2013/06/14/how-to-break-or-divide-an-oversized-pst-file-into-multiple-parts/
Thanks and regards.
SanDERR
Re: Split PST Files
08/08/2014 5:21 AM
Splitting of a single .pst file into multiple .pst files is done to avoid corruption. There are some manual techniques to break or split a big .pst file into several .pst files. You can implement by using "Import and Export" wizard or by using "Archive" feature.
Both the features support splitting PST files and you can get the steps from http://nalavadebela.wordpress.com/2014/03/15/how-to-split-and-merge-outlook-pst-files/
Re: Split PST Files
11/26/2020 3:39 AM
Hey, if you want to split the PST files into multiple files then you can use the best and most reliable PST Splitting Software. It can smoothly split the large-sized PST files. It split the PST files without any type of data loss or damage to the original structure & properties of the file. It comes with a user-friendly GUI that makes it easy to use even for non-tech users also.
For more info visit:- https://www.msoutlookhelp.com/pst/splitter/
Re: Split PST Files
08/20/2014 2:41 AM
Large PST file usually slows down the Outlook performance, causes sudden Outlook crash or permanent data loss (due to corruption). In mean time, it's necessary to split oversize PST file into more manageable small sized file with some utility that can split large pst by selected size, date or by year. As precaution is better than cure.
So Try:- http://www.recoverydeletedfiles.com/split-pst-tool.html
Re: Split PST Files
11/09/2014 11:41 PM
Use to simple manual techniques splite PST file, The software maintains data integrity of the original PST file. After splitting a large-sized PST file into smaller pieces, they can be easily accessed with MS Outlook and are completely independent of original PST file.
Use this link for more information:- http://sonikarawat.wordpress.com/2014/07/09/perform-split-operation-to-split-pst-file-into-multiple-pst-files/
Re: Split PST Files
03/16/2021 9:24 AM
Go to the Home screen, open the default PST file and select the items which you want to move to a new PST file you created. For this, click on Move button from the top and select Copy to Folder option. Next, choose the PST file from the copy the selected items to the folder option and click OK.
Hope this helps.
Regards,
Caleb
Re: Split PST Files
03/27/2021 6:27 AM
Step 1: Set Outlook to the archive by Received Date
Received Date button before you start, you must configure Outlook to archive based on the Received date rather than the Modified date. This way, you prevent emails that have been modified or imported after your archive date from remaining in your main pst-file.
The process to do this is described in the previous tip:
Archive based on Received instead of Modified date
Step 2: The Archiving process
Archive.pst button now that Outlook is prepared, you can split your pst-file in the following way:
Open the Archive dialog.
Outlook 2007
File-> Archive…
Outlook 2010 / 2013 / 2016 / 2019 and Microsoft 365
File-> Cleanup Tools-> Archive…
Select: Archive this folder and all subfolders
Click on the top-level folder to select the entire mailbox rather than the currently selected folder.
Set the “Archive items older than:” date to the 1st of January of the year after you want to create your first archive for. So if you want to create your first archive for 2011 and previous, set the date to the 1st of January 2012.
Optionally, check the option: Include items with “Do not AutoArchive” checked.
Specify a name and a location for your pst-file for 2011 and previous. Make sure that this is a location on your local computer and not a network share.
Example: D:\Documents\Outlook Files\2011.pst
Click OK.
Regards,
Caleb
Re: Split PST Files
02/03/2015 2:09 AM
Try third party Split PST software and effectively manage your large Outlook PST files into smaller pieces according to date, year, size, and folder. Read more and free download click here :- http://www.undeletepcfiles.com/split-pst-file.html
Re: Split PST Files
06/26/2015 5:12 AM
The Stellar Phoenix Split PST Tool can select the PST file of large size from any location and divides it in several PST files of small sizes. It uses its own PST splitter to avoid the risk of corruption of PST files due to the issue of being over-sized. It is available in Corporate License and Home User's License.
Get more information form here:- http://www.mannatsoftware.com/stellar-phoenix-split-pst.html
Re: Split PST Files
08/05/2015 5:10 AM
Re: Split PST Files
08/23/2019 1:13 AM
You can try ToolsGround Split Outlook PST Software to break your Oversized PST file into small size PST. This tool provides options to split PST file by specific size, folder, & year. You can easily download this tool.
Split PST Files
08/07/2015 1:40 AM
Managing the large size Outlook PST file to small parts according to date, year, size and email id basis. You can try Kernel for PST Split tool which is well works on all MS Outlook and Windows OS. To know more information, visit to: http://www.splitpsttool.net
Re: Split PST Files
07/11/2016 9:25 AM
Due to the PST file size restriction on Microsoft Windows Outlook email client application, causes a problem of oversized and sometimes leads to corruption of data. However, new PST Unicode file format allows users to store 20GB to 50GB data. Sometime 50GB space also exceeded by user PST data file and need to split in a multiple files.
This tool gives a nice interface and efficient way to split your large size PST to small PST files.
Visit -:http://www.pst-splitter.com/
Re: Split PST Files
04/13/2017 8:57 AM
The Stellar Phoenix PST File Splitter will split your large Outlook PST files into smaller files while protecting them from possible corruption caused by PST size limitation. It splits these larger files into smaller files you can manage easier, based on the particular PST split criteria, including Mail Id, Folder, Size and Date.More details about software is available here:- http://www.mannatsoftware.com/stellar-phoenix-split-pst.html
Re: Split PST Files
04/13/2017 9:02 AM
The Stellar Phoenix PST File Splitter will split your large Outlook PST files into smaller files while protecting them from possible corruption caused by PST size limitation. It splits these larger files into smaller files you can manage easier, based on the particular PST split criteria, including Mail Id, Folder, Size and Date. more details about software is available here:- http://www.mannatsoftware.com/stellar-phoenix-split-pst.html
Re: Split PST Files
06/18/2018 1:08 AM
Split is a process which act to break files which are in large size. In Outlook Application Split function plays a vital role and it helps to open/access large sized PST files created by any version of Outlook such as 2016, 2013, 2010, 2007, 2003, 2000, etc. Now move to post where is the introduction of Split PST Tool. Split PST Tool break the PST file in some small PST files by Date, Size and Email ID.
Know more about: http://recoveryandmanagement.com/best-way-to-split-large-outlook-pst-file/
Re: Split PST Files
09/28/2018 3:58 AM
With PST File Splitter, one can split the PST file according to size, date, Mail ID, Folder. The software is known to assure you to maintain the originality PST file after splitting it.
Download it from here: https://download.cnet.com/SysInfoTools-PST-Split/3000-2369_4-75744183.html
Re: Split PST Files
05/04/2019 12:51 AM
Try Split PST File Software is outlined to split large pst file into small size pst files on the basis of sender's e-mail IDs and date. The interactive user interface makes it easy to split pst without any prior experience. It is fully capable of splitting all MS outlook item such as folders, contacts, calendars, journals, email folders. It also supported by MS Outlook 2003, 2007, 2010, 2013 or 2016.
You can download this software here:- http://www.splitpst.filefixutility.com/
Re: Split PST Files
09/21/2019 6:26 AM
I would like to suggest try Shoviv PST Splitter tool that easily Split your Large Outlook PST files into multiple smaller PST's.
Get this tool from here: https://download.cnet.com/Shoviv-PST-Splitter/3000-2369_4-77701493.html
Re: Split PST Files
09/27/2019 5:41 AM
I would statement this ToolsGround split pst file tool split Outlook PST tool to every user searching for PST split utility. The user can try the software’s free demo version. Split PST software has been developed for splitting oversized Outlook PST files into smaller PST files. download this application.
Visit here: https://www.toolsground.com/split-outlook-pst/
Re: Split PST Files
11/18/2019 2:42 AM
If anyone wants to split the large PST files into small parts then I would suggest trying to use the KDETools PST Splitter. It splits the large PST files into small within few minutes. It is easy to download.
Featured:
  • It divides the large PST files on the Date.
  • It divides the large PST files on Size.
  • It divides the large PST files on Year.
  • it divides the large PST files on Folder.
  • This tool easily supports ANSI and UNICODE.
  • It split the large PST files without installing MS-Outlook.
  • It supports all the Version.
More Details: http://www.pst-splitter.com/
Re: Split PST Files
12/10/2019 5:11 AM
Split PST files which helps avoids large PST corruption by dividing and categorizing them in smaller files. It uses its own PST splitter to avoid the risk of corruption of PST files due to the issue of being over-sized. It is fully capable of splitting all MS outlook item such as folders, contacts, calendars, journals, email folders. It avoids corruption in PST files and divides large-sized PST files into smaller files. And also supports all versions of MS Outlook like 2000, 2002, 2003, 2007, 2010, 2013 and 2016. if you know more information about this software then visit here:- https://www.sametools.com/split/pst/
Re: Split PST Files
12/10/2019 10:26 AM
The product is an ingenious way of solving the problem of handling large PST files.
Thanks for the product.
Re: Split PST Files
01/14/2020 2:37 AM
Hello
Due to large PST files in Outlook, my system is working very low then I search the PST Splitter tool is KDETools PST Splitter. After use PST Splitter my large PST files split into small parts within few seconds with 100% safe original data.
Re: Split PST Files
02/03/2020 4:10 PM
This information relevant for me, thank you a lot!
Re: Split PST Files
03/06/2020 12:56 AM
If your pst files get very large? if use then you should use this PST file splitter which can also split large PST file in few mouse clicks without data loosing.The split PST files can be smaller than 200 MB and larger up to 2 GB. You can split the existing PST file at any time you feel it is exceeding its limit. You can split it into any of your desired sizes to avoid the problems of corruption in future. Visit here to know more:- https://www.recoverydeletedfiles.com/split-pst-tool.html
Re: Split PST Files
08/07/2020 8:07 AM
Split PST files to control data corruption of large-sized files is a troublesome task for many Outlook users. From what I have gathered, there are a ton of tools that can help you with the splitting of PST files on Mac.
However, if you are seeking out for a PST splitter for windows, analyze the Shoviv PST Splitter tool.
Let's cover some of its valuable features:-
1- Splits many PST files at once in no time.
2- holds the Meta characteristics of the email.
3- Operates smoothly in all versions of Outlook and Windows OS.
Uncover more features of this tool, here:- PST Splitter
Re: Split PST Files
11/06/2020 6:38 AM
Split all the Outlook PST files with the help of the best Outlook PST split tool. With this tool, you can split the large PST files without any issue. Also, there is no data loss during the split process. You can split PST files of any size and there is a problem during the split process.
Re: Split PST Files
07/29/2026 6:03 AM
If your Outlook PST file has become too large, splitting it into smaller parts can help improve Outlook performance and reduce the chances of file corruption. A large PST file may cause slow Outlook response, synchronization issues, difficulty in opening the data file, or errors while accessing emails.
You can split a PST file by date, size, folder, or email ID based on your requirement. Before splitting, it is recommended to keep a backup of the original PST file to avoid any data loss.
For a simple and reliable way to divide a large PST file into smaller files, you can use SysTools PST Splitter. It allows users to split PST files without affecting the original mailbox data and provides options to split by size, date, year, folder, and more. The tool supports large ANSI and Unicode PST files and helps manage oversized Outlook data files efficiently.
After splitting the PST, you can import the smaller files into Outlook and continue accessing your emails smoothly.
Re: Split PST Files
09/17/2026 5:03 AM
You can easily split PST files using the best tool. A few days ago, I faced the same problem. When I searched Google, I found two options: the first option was manually, and the second option was a third-party tool. The manual potion is risky, though. For this reason, I went with the third-party tool, the best tool for splitting my PST files easily. I highly recommend using the MailsDaddy PST split tool. This software can split PST files into smaller PST files by subject, date, size, folder, and year. When splitting multiple PST files at once, the application maintains the original PST file structure. The information is useful for both technical and non-technical people. All versions of Windows OS make it easy to use. Microsoft Outlook is compatible with all versions, including those from 2021, 2019, 2016, 2013, 2010, 2007, and more. Download the trial version now to test out the program's primary features.
Register to Reply 31 comments
7john (1); 97harry brown (1); AbigailF (1); Abrienne (1); albertsoms (1); bruceoxenford (1); caleb_cruze (2); carolyn (1); charlesbherrera (1); James156 (1); Leejuny83 (1); leodjik (1); lilywilson (1); Madelynbloton (1); mullermarie (2); NathanStevens (1); NecVolt (1); nicholasramirez (1); Phillcalls (1); rajatjaw (1); Rawatsonika4u (1); rubydills (1); sandyMD (2); Sanjeev9910 (1); savoie (1); sophia bennett0550 (1); stevensmith (1); zesid (1)
