Previous in Forum: Transformer- Find Location of Partial Discharge   Next in Forum: New Battery for Laptop, Commissioning
Underground Cable
05/29/2014 1:26 AM
Is there any difference of insulation level for 3 core & single core u/G cable e.g. Thickness of XLPE, semiconducting layer etc for same cross section area of conductor.
Pathfinder Tags: underground cable
Re: Underground cable
05/29/2014 2:25 AM
Come on, Mildred. Make a phone call or two to a couple of cable suppliers!
Good moaning!
Location: KCM, chingola; copperbelt; zambia; southern africa.
05/29/2014 8:35 AM
you need to go underground see the environment, the see how foolish it will feel to ask such a question. temps are high and its wet.
an error does'nt become a mistake if corrected!
Good Answers: 42
Re: Underground Cable
05/29/2014 12:46 PM
In my opinion the insulation thickness , conductor shield and insulation screen -and all other parts -except armour and serving - are the same for the same rated voltage.
In USA U.L. standards state the cable building rules .See:
UL Standard 1072 Standard for Medium-Voltage Power Cables
For IEC world see: IEC 60502-2 Cables for rated voltage from 6 kV up to 30 kV.
Julius
05/29/2014 3:41 PM
Yes and no depending on the application.
Try looking at cable manufacturer's websites for more details.
05/30/2014 12:16 AM
In India it is NO . Special considerations can be paid by the owner if one needs to. But yes, As all around the world the cable capacity gets de-rated.
Let us discuss the practical issues not the classroom.
05/31/2014 1:12 PM
Insulation thickness of ue rated cables higher than earthed system cables due to sqrt^3 times higher voltage between phases during earth fault in unearthed system
Good Answers: 42
06/22/2014 2:45 AM
You are right, tigerdon. The grounding fault duration state the insulation thickness.
From IEC 60502-2 ch. 4.1 Rated voltages:
"The rated voltage of the cable for a given application shall be suitable for the operating conditions in the system in which the cable is used. To facilitate the selection of the cable, systems are divided into three categories:"
Category A: ground fault is disconnected from the system within 1 min.
Category B: ground fault is disconnected from the system within 1 h. [up 8 hours could be tolerated if the total duration in one year should not exceed 125 hours.]
Category C: [more than category A or B].
Table 1 presents the recommended rated voltage-to-ground [or neutral] Uo. For category A and B it will be a half of maximum permitted phase-to-phase. For C category more is required.
Category A corresponds to 100% and Category B to 133% insulation level according to UL 1072.
Julius
Register to Reply 7 comments
7anoter4 (2); Crabtree (1); DmanEng (1); jack of all trades (1); M.R.Iyengar (1); tigerdon (1)
