Hey guys!
Along with some colleagues, I constructed a test stand for LSDs. (Limited-Slip Differentials I mean, not the other....) The purpose of the test stand is to determine the torque necessary to spin one wheel against the other when the clutch-type LSD is pre-loaded to some extent. One axle side is driven and the torque acting on the shaft is measured, the other side shaft is kept stationary. Here it comes:
I'm using a rotary torque transducer connected to a PC-DAQ system. During the times the drive motor is engaged, the readings seem to be accurate, but when the motor shuts off and slows down (until stop), I get strange readings of an all-too-constant torque of about a 5th of the peak value measured.
As far as I understand the mechanics behind the experimental setup, the torque readouts should not be dependent of the decrease in RPM of the drive motor, especially because the the measurements are performed at low RPM anyway (40-90 RPM).
The drop in the readout is coincident with motor shut-off which is independently controlled - seperate from DAQ circuitry.
I've already contacted both sensor and software manufacturers and neither can reproduce nor explain this outcome.
Anybody have a clue what could be the problem or how to resolve this issue? Thanx!
