Basically this is only usefully for checking anode to cathode short circuit and gate circuit continuity.
It is not practical to try to use Avo meters battery /ohms circuit to check functional operation due to variables like minimum hold on current,gate trigger voltage and current.
Practical way is to use a 6Volt battery and small lamp wire them in series then momentarily connect a 0.1 Mf capacitor between gate and positive supply this should switch thyristor on if it is good also can test a triac by same method.
