Previous in Forum: Theoretical Data Transfer Rate   Next in Forum: Battery 3 Stage Charger
PFC Controller Circuit Problem
06/06/2014 2:15 AM
Hi. Im doing power factor correction and using acs712 to current sensor it need 5v vcc wich i supply from bridge rectifier and regulated ac from 7805 but when connect in simulation voltage output of sensor become 33v.
Re: pfc controller circuit problem
06/06/2014 2:21 AM
Like to help, but can't see your circuit from here.
06/06/2014 4:26 AM
this is the circuit. please help where is wrong.
06/06/2014 4:37 AM
This is what I see:
Still not much help.
Good Answers: 50
06/06/2014 8:08 AM
What simulator are you using? Where did you get the model for the ACS712 hall effect current amplifier? Does the model have output clamping to simulate the common mode +5 supply?
ignator -
Re: PFC Controller Circuit Problem
06/08/2014 10:16 PM
I presume it is a result of translation error, but you get regulated DC from a 7805.
Make sure your circuit image is in JPEG format, and it should post correctly.
dkwarner (1); ignator (1); JohnDG (2); lhaggai (1)
