Previous in Forum: Armaflex Similar Product   Next in Forum: How to Calculate Allowable Stresses?
Join Weld Skirt to Base Plate
06/11/2014 5:10 AM
hai there
could anyone tell me how to weld joint of Skirt to Baseplate on Silo 100 ton base on ASME Sec VIII div. 1 or other standard..
thickness of skirt 10mm and thickness of base plate 30mm
can I welding with intermiten filled weld joint?
thank you
Yan
Re: Join Weld Skirt to Base Plate
06/12/2014 2:55 AM
"A picture is worth a thousand words." I have an idea of the nature of your enquiry but I am not exactly sure. Please produce a sketch showing the plate thicknesses, the diameter of the skirt and the position of the proposed welding.
06/12/2014 5:06 AM
Did you refer your engineering specification?
If the info. is not available in specification, provide complete design details with drawing of the particular joint for a deep analysis.
Register to Reply 2 comments
