Previous in Forum: Solar Energy Calculations   Next in Forum: Burning of Fuses of a DC Drive 95KW
Location: crankshaft producing hub in belgaum,karnataka,india
Response of Ferrite Powder
06/15/2014 9:49 PM
Can any one high light the behaviour of ferrite powder (N87 grade) when placed in a high frequency and high voltage field. this powder is placed in the vicinity of the current carrying electrode which is sealed in a refractory sheath.
Re: Response of Ferrite Powder
06/15/2014 10:14 PM
The iron assumes the pattern of the magnetic field...
06/15/2014 11:11 PM
It will get hot.
Is there a real question here?
06/16/2014 11:49 AM
Dear Sir,
thanks for the reply.
The problem is that I am using it as a filler compound beside the copper electrode which is sealed in a refractory sheath, The refractory sheath is a tube of wall thickness 3.5mm which acts as a dielectric on surface of which corona is generated in the presence of high voltage and frequency of 300 Khz.
Does ferrite contribute to increase in density of plasma generated, If not can Barium titanate give good results.
06/16/2014 12:40 PM
I can't say.
My feeling is BaTio3 would be better, but I've only used it as a dielectric waveguide filler to adjust frequency.
Good Answers: 109
06/16/2014 12:58 AM
Did you try it? What did it do?
Is your ferrite already magnetic? It will probably take on magnetic properties when exposed to a magnetic field or it will change the properies and poles depended on what you expose it to.
Have fun!
IdeaSmith (1); lyn (2); ravi bagewadi (1); SolarEagle (1)
