Previous in Forum: What Rate of Amps Can I Charge Deep Cycle Battery?   Next in Forum: Stabilizer for Air Conditioners
8 comments
Engineer
07/18/2014 12:49 AM
the impedance of autotransformer varies when tap changes but what is the condition or type of the transformer in which the impedance remains unchanged while changing tappings of the transformer
Re: Engineer
07/18/2014 7:41 AM
Theoretical
Re:Student
07/18/2014 9:36 AM
Ideal.
Good Answers: 804
Re: Engineer
07/18/2014 10:21 AM
Ideal. Which is, coincidentally, theoretical!
Re: Engineer
07/18/2014 11:09 AM
Imaginary - Theoretical -Ideal -
Re: Engineer
07/18/2014 11:11 AM
No the imaginary part is pure reactance.
Re: Engineer
07/20/2014 3:48 PM
Impractical in a transformer, but possible I believe electronically using an op amp configuration (but at limited voltage and current).
What's the application exactly?
Location: I live in USA, Colorado in the houses of 7 Summits
Re: Engineer
07/25/2014 6:37 AM
Transformers are bi-directional and it works independently without knowing where the input is connected, an ideal transformer impoese no load on the supply, Ideal Transformer remains its impedence unchanged while changing tappings of the transformer.
Anonymous Poster #2
Re: Engineer
08/06/2014 4:47 AM
If you through six eggs in the air, their will be one off them that does not break when landed.....you will find the solution inside that one
Anonymous Poster (1); jack of all trades (1); JRaef (1); LongintheTooth (1); lyn (1); redfred (2); ShawnHoppe (1)
