Dear All Guru's,
The designer specified 300 Microns paint thickness on our carbon Steel(A36,A-283C) Potable Water tank of 60 Meter cube capapcity.
However during our UT thickness measurement the paint thickness measured & observed as 200~250 Micron in the lower thickness range and 550 ~ 659 Microns in the upper thickness range.
What should be allowable limit for accepting any specified paint thickness range for the Industrial Application, i.e. from what minimum thickness to what maximum thickness range the paint thickness should be considered as accepted and after what range it should be outrightly rejected. Is there any support document/codes/specification for this allowance limit range.
Thanking you in anticiaption of an early answer
VKJ
