Previous in Forum: 20 Years Suddenly No Power In One Room.   Next in Forum: Lighting in Confined Silo
13 comments
Steel Wire and Steel Tape Armouring
08/12/2014 1:44 PM
Dear all
good day
please what's the difference between steel wire and steel tape armouring
Re: steel wire and steel tape armouring
08/12/2014 2:41 PM
One uses wire, the other uses tape. (flat wire)
wire / Tube 2014 - Armouring Steel Tape - Galvanized Wire ...
08/12/2014 3:12 PM
By Jove, I think I even agree with you on this one!
common knowledge...less common than common sense
08/12/2014 4:33 PM
Dear sir
Thank you for your interest,
But where is used each
In other words, when I can use both of them and whichever is best
Best regards
08/12/2014 4:38 PM
Open this: wire / Tube 2014 - Armouring Steel Tape - Galvanized Wire ..., then read it.
It gives the uses.
Frankly, I am at a loss as to what you really want.
Is this just idle curiosity or are you taking a test?
You can hire a tutor if you want someone to teach you the fundamentals of wiring.
<unsubscribe>
08/12/2014 4:57 PM
Dear sir
we need to laying power cable under ground,and we have both type.
Which is better to use steel wire or steel tape armouring
best regards
08/12/2014 5:37 PM
Steel tape.
Good Answers: 181
08/12/2014 3:06 PM
Depends on what the tape is. There's several types and materials used, each has a separate purpose.
Look on a manufacturers site.
08/12/2014 3:16 PM
Choose one for the type of interference you would prefer to prevent, in addition to strength characteristics...it's a trade-off or can be complementary.
08/12/2014 3:48 PM
Armoring and shielding are not the same thing.
08/12/2014 6:55 PM
Agreed...
...but, shielding is a side benefit to a good armor.
From your link: Armouring steel wire is made of galvanized steel wires in round and formed sections. These wires are commonly used for the protection (prevention of accidental damage), the provision of additional strength, and for earthing of all grades of electric cables.
I have been doing some testing lately with the steel armor wires on some of our longer cables where they terminate in the lightning protection cabinet. I have found that the armor performs quite well as a shield.
You are right, though, in that the OP specified armoring.
Re: Steel Wire and Steel Tape Armouring
08/14/2014 9:01 PM
Both are the same for shielding the leakage current and for earthing purpose. It depend on what type of cables you are using and what type of shielding you require and how you lay your cables at what type of environment and location and area.
08/14/2014 9:58 PM
Simon Wan,
Please refrain from sending any more threads. You are dispensing useless, dangerous misinformation.
lyn
Good Answers: 42
08/17/2014 10:10 AM
I think the flatten wire is thinner [only 0.8 mm according to IEC 60502] but round wire could be 4 mm diameter. That means the round wire armored cable is stronger and could be pulled at longer distance.
However the overall diameter is increased and the losses are more elevated.
That poses the problem of passing through conduit and the derated ampacity.
Julius
Register to Reply 13 comments
7anoter4 (1); ASSER (2); lyn (5); Simon Wan (1); The.Tinkerer (3); TonyS (1)
