Previous in Forum: Query on Injection Moulding Machine Tonnage   Next in Forum: Seizing (Binding) of Stainless Steel
Cold Roll Mill
08/15/2014 4:07 PM
Does anyone know the roles involved in cold roll milling plant? I mean from production manager to the least operators. Kindly help in breaking down if you know.
Pathfinder Tags: Cold roll mill (CRM)
Re: Cold roll mill
08/15/2014 4:15 PM
The roles are the same as with any production facility. Look on Google for factory worker roles.
Why do you want to know?
Interview question?
Homework?
Want a promotion?
Re: Cold Roll Mill
08/17/2014 3:52 PM
Want to start up a new cold roll mill?
Hey, it wouldn't be the first time someone asked a large business start-up broad question here on CR4.
Canada - Member - New Member
Re: Cold Roll Mill
08/29/2014 9:59 AM
If this is a new start up, then there should probably be enough $ to hire someone with the experience to do this. Every aspect of manufacturing is just a little bit different.
Never stop learning
Re: Cold Roll Mill
08/25/2014 12:54 AM
This is management organisation chart where the manager suppose to know how to plan his organisation chart and who is suppose to be on top and who is suppose to be at the bottom and how is he going to run the plant. Every plant has its different way to organizing his manpower.
Register to Reply 4 comments
jack of all trades (1); Kevin LaPaire (1); lyn (1); Simon Wan (1)
