Previous in Forum: Chlorine & Hydrogen Psychrometric or Mollier Chart   Next in Forum: Failure Analysis of a Failed Steel Rope
Prusa i3 at Higher Speed
08/28/2014 10:02 AM
I am running on a Prusa i3 and at higher speed settings only one of my motors runs. When I lowered my steps per mm in marlin the issue went away. Do you guys think it could be a current issue or a motor issue?
Thanks
MRO Supply
Pathfinder Tags: Prusa
Re: Prusa i3 at higher speed
08/28/2014 1:54 PM
Low current...
Use RampsTestCode to excercise the servos. Each stepper needs tweeked until movement is minimum, then give it a 1/4 turn.
common knowledge...less common than common sense
Good Answers: 88
08/29/2014 12:55 AM
I'll raise you a low stepper driver voltage issue and/or a too high voltage speq stepper issue. S.M.
Register to Reply 2 comments
