Previous in Forum: Energy, Food for Thought   Next in Forum: ‘Cloaking’ Device Uses Ordinary Lenses to Hide Objects Across Range of Angles
15 comments
Good Answers: 97
Waveguide Repair
09/29/2014 12:59 PM
Although there are no specifics for the nature of the damage to the FAA center in Aurora Il.
What is involved in repairing damage to waveguides?
CRTL-Z
Pathfinder Tags: Waveguide repair
Re: Waveguide Repair
09/29/2014 1:02 PM
With no information on sizes and material it is difficult to say, Boss. So I'll set the ball rolling with a can opener and a pop rivet gun. Owzat?
Is there a prize for getting it right?
Good moaning!
Good Answers: 97
09/29/2014 1:08 PM
There is a prize Stenson. A genuine British prize bar.
Don't forget the gold plated waveduct tape.
CRTL-Z
09/29/2014 1:35 PM
Depending.on the frequency they are mostly not repairable.
Any scratched or warped.interal surfaces will degrade the performance. Reflected energy is not good.
They should be replaced.
09/29/2014 1:33 PM
It is unlikely that the waveguide itself is damaged beyond useful repair. Waveguide is nothing more than precision pipes. Often bad waveguide is replaced instead of repaired. If the internal cavities were exposed to smoke damage then careful internal cleaning to get any soot out of the cavity before it can be possibly reused. Once the waveguide path ways have been reconfigured there maybe a need to perform the RF black magic of dent tuning the waveguide.
Much more critical is when the waveguide was damaged, it could have taken out many very expensive, long lead time components:
  • Power amplifiers (traveling wave or klystron tube amplifiers)
  • Low noise amplifier
  • Magic T
  • RF power isolator
  • Waveguide filters (both pass and time equalising)
Good Answers: 145
09/29/2014 3:20 PM
I used to be around some rather interesting characters. One of them claimed to have done 120 GHz work before 120 GHz existed (wink). He claimed that he was provided with a huge tool box that was nothing more than calibrated ball bearings, calibrated magnets and a very wide assortment of calibrated hammers. He claimed he would tune up a system by dropping in a ball bearing and moving it around with a magnet on the outside of the wave guide tube. Based upon his knowledge of black magic he would then decide to either leave it in place, roll it out and replace it with a different size ball bearing or use a precision hammer to make a precision dent. He might do this for days before he was happy.
I suspect that everything was machined down to the thousandth's of an inch. Using a hammer to make the system work properly seemed so silly that it probably was true.
All this was done while wearing a pointed purple hat with big white dots on it. They wouldn't let him wave his wand around or sprinkle pixie dust.
09/29/2014 3:31 PM
Radio astronomy work in the 120 GHZ range was performed before 1984? Would you prefer a citation from 1974 instead.
Good Answers: 918
09/29/2014 6:18 PM
Heat could warp the metal.
I have no idea what actually happened at the cite, so my response is simply for academic interest.
Good Answers: 114
09/29/2014 7:04 PM
"I have no idea what actually happened at the cite, so my response is simply for academic interest."
I like this, I hope it was deliberate.
Good Answers: 918
09/29/2014 7:13 PM
I wish I could say it was, but I failed to sea it at the time. ;-)
09/29/2014 7:18 PM
The site was not a pretty sight.
Oh, OH!!!!! Unredundant, is that a gull wing Stenson?
Oh, never mind, the gull wing is a Stinson.
09/30/2014 12:43 PM
Can I cite you on this one?
Good Answers: 97
09/29/2014 1:56 PM
Whatever happened, the damage must be extensive. Might even involve phased array multiplexing and no wave guides.
CRTL-Z
09/29/2014 3:19 PM
Oh well. Weigh them in for scrap and get new ones. That is what is involved.
Good moaning!
Good Answers: 26
09/29/2014 2:48 PM
Bringing them back to nominal print dimensions and performance qualifiers.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
10/03/2014 8:31 AM
We are talking FAA here, it is very unlikely they used anything much above 20 - 25 ghz, likely much lower....what i would do is check the S-parameters before and after the repair, and decide if the degradation in performance due to the repair is acceptable compared to the cost of replacement.
BSEE but always learning
Register to Reply 15 comments
1capybara (1); Anonymous Hero (2); Brave Sir Robin (1); BruceFlorida (1); Crabtree (2); lyn (2); passingtongreen (1); redfred (2); texasron (1); Unredundant (2)
