Previous in Forum: Ebola - Can We Make an Engineering Contribution?   Next in Forum: Efficiency of AP
20 comments
Good Answers: 143
What is This??
10/10/2014 12:30 PM
Does anybody recognize this thing? I got this in a box of stuff with an old South Bend lathe. The two slices of material in the slot in the first picture could be really dry leather or perhaps some sort of fiber - it's hard to tell. The gray paint is not original.
Re: What is this??
10/10/2014 12:58 PM
My WAG is a tool support for using a wood chisel on a lathe. That is if this is a wood lathe.
Good Answers: 143
Re: What is this??
10/10/2014 1:50 PM
No, it's an old 9" Workshop metal lathe. It runs too slow for wood, and has friction bearings, so you can't speed it up too much.
Re: What is this??
10/11/2014 11:22 AM
I have a pretty ancient Atlas lathe with back gears. If you swing the back gears out of engagement, and push in a pin on one of the main shaft gears, it will turn much faster--adequate for wood. Will yours do something like this?
Lehman57
Good Answers: 143
Re: What is this??
10/11/2014 12:55 PM
Nah, it only gets up to about 630 RPM. Their sales literature in 1934 promotes this as good for wood, but you really need more like 1500 RPM or so for smaller pieces (I'd like to get around 75 ips for smooth cuts on a lathe. The old bearings on this won't take it. I suspect your Atlas uses Timken roller bearings? You can run those faster.
Good Answers: 143
Re: What is this??
10/26/2014 7:51 PM
I wanted to reply back. I thought about what you do with yours, and kept asking around. I finally found somebody who knew how to run the SB fast. All you have to do is treat it like a car engine (which after all runs plain bearings). You back off the bearing clamp bolt about 1/16 a turn, and you flood the bearings with Mobil #1 OW30 extreme high detergent synthetic oil. That oil and the increased bearing spacing is about right for floating the spindle in the oil. As soon as I get a motor set up on the countershaft to run faster (I need a 3450 RPM motor and I don't have one at the moment), I'll try this out.
Re: What is this??
10/10/2014 2:05 PM
Any screws or locking devices on the hollow arms?
What is the number on the "face"?
Good Answers: 143
Re: What is this??
10/10/2014 7:29 PM
No locking devices or tapped holes, anything like that.
It has M-1262 on the face.
It almost looks like you would have pushed some sort of thin plate, maybe 3 1/2 " wide in there, but why?
Good Answers: 151
Re: What is this??
10/10/2014 2:53 PM
My guess is that it is some type of boring bar holder. Are there set screws on the flats and is the IDs accurate? This could have been used to turn the ID and OD of a part in a single pass. Probably made for a specific production job.
Good Answers: 143
Re: What is this??
10/10/2014 8:52 PM
No set screws. The IDs appear as cast (of course they may have rusted and been painted. But, I don't think it's right for boring bars.
Re: What is this??
10/11/2014 5:58 AM
That first pic looks like a model of R.M.S Titanic .
Any threading in those holes (not sure what you mean by "no set screws") ? NSS has already trashed my weekend with that curious desk type thing.
If you've got time, can you take a few more pics from different angles. The 'where and when did you get it' might also help.
I haven't got a scooby what the thing is, but will read with much interest. CR4 IHS Whoever may have just regained some of it's personality. I can now tell Mrs K that I do indeed visit here to learn curious and interesting stuff ! So long as she doesn't suss that I'm posting via phone down the pub, all is safe .
Good Answers: 143
Re: What is this??
10/11/2014 7:11 PM
Here's a few more pix
Nothing is threaded. Not sure how to explain set screws - it's that language barrier, eh? They're short, headless screws, usually hex wrench drive, that go sideways into a hole to grasp a shaft. You see them on shaft collars, pulleys, that sort of thing.
The "thing" came in a box of extra parts that I got when I bought this 1933/34 South Bend lathe,
I got this off the son of a deceased crane repairman/operator. The son was pushing 70, so the old man would have been in his 90s, I guess; no telling how long he had this. He clearly had found a bargain on battleship gray paint at some point; everything he had was painted that way. A shame - these lathes were originally a beautiful blue-gray or gray-green, depending on something that I don't know. There were a lot of weird things in the box I got, but everything else could be identified.
BTW, I envy you guys in the UK. You have access to lots of Myfords, many of which are quite nice. We have only South Bends and Atlas for a similar use. The South Bends are often worn out, and not worth regrinding, while the Atlas lathes are often missing essential parts or are at least $700.
I don't want anyone to think I don't like the lathe. I do. The South Bend 9s make a distinctive sound, not unlike the sweetness of a Merlin or the raw throb of a Harley. Sometimes I turn it on just to remind me of what a shop should be. I hate the efficient whine of a really top of the line Hardinge. I keep hoping I'll run into a replacement bed with better ways (this sucker, because of the Great Depression, came without way wipers and boy did they suffer for that).
Good Answers: 21
Re: What is this??
10/12/2014 12:50 AM
There are some very good old lathes around. Yours is just a bit older then the one I have. But, not buy that many years. The bed on mine was also worn. I removed the tail and head stock and re-scraped everything level. This only removed a few thousands from the two ends. Got the unit to cut pretty true again. Not much effort to make better ( but I must add I have a lot of years under my belt scraping ways).
Nice find. Keep it operational PM me if you need gears etc. If I can help I will.
Fixit
Good Answers: 143
Re: What is this??
10/12/2014 9:37 AM
I thought about re-scraping (I've only done that once, on a much smaller lathe), but I'm too green at that to undertake it unless absolutely, positively necessary. The trouble (for me) is that I'll still have a lathe with only one carriage clamp, no way wipers, poorly designed oiling ports, change gears, and cast iron bearings. I'm thinking I might be OK with this while I look for a better 9B, or even an Atlas (I saw a beautiful 618, with accessories, go for under $400 at an estate sale where they didn't know what it was. Unfortunately, I didn't see it first).
I mostly turn repair parts, that sort of thing, and I can get by for now. I've got to prioritize my pennies, and I'm trying to come up with a long bed jointer and spindle sander first.
How did you keep everything flat and coplanar on the ways? I can't figure out what to use for a test flat for such a large bed.
Re: What is this??
10/11/2014 8:13 AM
OK, a little more directed information is needed here. You claim that this nearly 6" long bracket works with a 9" metal lathe. Do those two stand-off holes have the same spacing as any other holes or pins on the yet to be seen lathe? If not then then I suspect this part has nothing to do with this lathe. It just happened to be in the same box as the lathe.
Good Answers: 143
Re: What is this??
10/11/2014 11:09 AM
Redfred, you're a genius! The c-c spacing is 2-1/2 inches. Nothing on a SB9 is 2-1/2 inches. I was fooled by the fact that this was painted with the same ugly paint as everything else on the lathe. I should have been suspicious, I suppose, because the guy I got it from had taken some old straight reamers and reground them to be Morse Taper reamers. It's obvious he did all sorts of repurposing.
I'm still curious what the heck this is. I'll get some more pictures and add. I'll even put up a picture of the beast itself - a almost worn out 81 year old lathe (wait a minute - isn't 80 the new 70?) that I ended up buying for -$11. It actually turns with only about 0.002" total runout in a 9" cut, but you gotta shim and indicate the heck outta it to get that. OK for my home basement.
Re: What is this??
10/11/2014 11:55 AM
A long shot but is it some sort of rest for a flaring / metal spinning tool?
Peter Jensen
Re: What is This??
10/11/2014 11:16 PM
Can you take out the leather/fibre to see if the sides of the slot are tapered? If yes it is possibly a sort of vice to hold sheet metal. It would hold buy pushing down on the leather/fibre. The two holes may have attached this 'vice' to a wood vice or something similar that has two guide bars.
Obviously not a big seller!
Jim
Re: What is This??
10/11/2014 11:23 PM
Maybe it attaches to a vice like this;-
To hold something like this;-
Jim
Re: What is This??
10/12/2014 3:36 PM
Could it be something to do with the belt drive? The gap looks about right. Is it for moving the belt over onto another pulley? Or could it be for attaching the belt link? My Schaublin has a fork for flipping the belt onto an idler pulley without stopping the motor.
Peter Jensen
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
Re: What is This??
10/14/2014 7:15 AM
contact http://www.southbendlathe.com/home.aspx
ask them if it's one of theirs
Nothing is fool-proof to a talented fool
Register to Reply 20 comments
fixitorelse (1); gringogreg (1); JIMRAT (2); Kris (1); Lehman57 (1); lonster (1); lyn (1); Pj3ns3n (2); redfred (2); TVP45 (8)
