Previous in Forum: How are Large Machines Made?   Next in Forum: Glass Manufacturing Process Details
Oil Viscosity @ 40'c ?
10/12/2014 12:02 PM
hi, I am Sunil.
I want to know that why oil viscosity measures at 40 degree c.
Re: oil viscosity @ 40'c ?
10/12/2014 12:17 PM
So all oil is measured under the same conditions.
There are other standard temperatures too.
Oil Viscosity - How It's Measured and Reported
Good Answers: 143
Re: Oil Viscosity @ 40'c ?
10/12/2014 10:47 PM
It all depends on the use to which you want to put the oil. For example, summer rated motor oil is tested at 100° C, but winter weight oils are tested at a variety of colder temperatures. If you lived in International Falls, and you wanted your truck to turn over on a - 28° F morning, you really wouldn't care what the oil did at 100° C. So, different standards bodies have different temperatures for testing.
What kind of oil are you asking about, and what is the governing standards body?
10/17/2014 9:39 AM
Check with ISO 3448.
10/31/2014 11:53 AM
Thanks to all of you.......
But I didn't understand that 40'c is it any standard?
Can we measure viscosity at 20'c?
What will happen if we use hydraulic oil (Tellus-46 from Shell) at 50'c?
10/31/2014 1:11 PM
"Can we measure viscosity at 20'c?" Yes, of course you can, if that is your performance criteria.
"But I didn't understand that 40'c is it any standard?" Yes, it is a standardized testing criteria for reporting, a temperature that is common. Many industries experience different temps in actual use, and it is wise to investigate potential products at anticipated temperature ranges that you may experience.
Doorman (2); galaxy_skr (1); lyn (1); TVP45 (1)
