Previous in Forum: Part Number Search   Next in Forum: bk
Induction Generation Project
07/05/2007 1:07 AM
I am electrical eng student want to realize induction generator project. What thing that I must know before start the project?
Re: Induction Generation Project
07/08/2007 2:42 PM
first things..... Where can we use induction generator?????????
Induction generator can be used where constannt speed of generator is not possible. like in wind turbine..
second things..... induction generator nothing but a induction motor,it should required a grid..for generate power induction generator must be rotated above its synchonous speed......supposed we have a 4 pole induction generator conected with 33kv 50hz grid..
then its synchronous speed Ns=120*f/p=120*50/4=1500rpm
i.e when induction generator rotated above 1500rpm it feed a power in grid insted of consume power from grid and if induction generator rotated below 1500 rpm then it consume power from grid..
Engineering Fields - Electrical Engineering - Ron Nombri Engineering Fields - Energy Engineering - Ron Nombri Engineering Fields - Power Engineering - Eternal Power Papua New Guinea - Member - Ron Nombri
07/09/2007 8:36 AM
Check this website www.qsl.net/ns8o/Induction_Generator.html , it should help. It contains infor. on An Easy to Build and Operate Induction Generator. I found it to be very good. It got the basics of what you would need to build one.
Kind regards, Ron
