Previous in Forum: How to Censor English Movies??   Next in Forum: Need to Adjust Pans Font Size of MS Office Outlook 2007
12 comments
Problem Watching HD Videos
11/03/2014 10:06 PM
Dear Sir,
I am facing problem to watch HD videos with following specifications. i am giving you just example of below specifications.
File Format, MKV
Resolution, 1280X720
whenever i want to open VLC & try to watch movie with full screen screen always freeze or play with as slow motion but no problem with small screen.
My system specifications are as below. Kindly help me in this regard.
Operating System: Windows 7 Professional 32-bit (6.1, Build 7601) Service Pack 1
System Model: Dell, OptiPlex 745
BIOS: Phoenix ROM BIOS PLUS Version 1.10 2.2.0
Processor: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz (2 CPUs), ~2.1GHz
Memory: 2048MB RAM
Available OS Memory: 2038MB RAM
Display Devices,
Card name: Intel(R) Q965/Q963 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) GMA 3000
DAC type: Internal
Always Respect Your Seniors. Best Regards, Ahmad Arshad
Re: Problem to watch HD Videos.
11/03/2014 10:21 PM
Some videos have a tendency to be jerky, if edited.
Maybe you need a:
Free MKV Player - CNET Download.com
11/04/2014 6:06 AM
'jerky if edited' - LOL !
I'd be wary of CNET. It used to be fairly good, but thesedays will stick you with a load of PUP's and toolbars unless careful. That said most download site I know have gone that way.
Dear OP : Once you have sorted this issue, is there any chance of some feedback about how you got on with the previous question ? With some judicious timing the goal may be possible with Windows built in software.
When you find the right software watch out for all the check boxes that might download unwanted clutter to your computer. Some of it can be a real pain to remove.
Re: Problem Watching HD Videos
11/04/2014 8:35 AM
A common problem with jerky video playback in HD at full screen size is that the processor simply can not handle the data fast enough.
Both of my toughbooks do exactly what you are describing and it simply because they can not process all the info for a full screen.
Now if I cut the HD stuff down in size or run it through my All Video Converter program and reduce the resolution there is no problem.
Unfortunately now a days 2 gig of RAM and 2.1 GHz of dual core processor is not enough to handle high action HD work.
The only easy fix is a to run a dedicated video card (if possible) that does all the HD video work freeing up your main processor.
11/04/2014 10:53 AM
"A common problem with jerky video playback in HD at full screen size is that the processor simply can not handle the data fast enough."
But it tries to, and heats up... a lot.
I had a similar issue. When the video image started jerking I checked the processor temp and it was WAY high. Improved cooling for the processor and that fixed my particular issue.
11/04/2014 10:27 PM
Dear Sir,
Thanks for your advices but is it possible you give me some tips to resolve my issue because currently i unable to purchase new CPU... please give me some tips (if possible)
11/04/2014 11:25 PM
Doorman just gave you one! Put a fan (or a bigger one) on your microprocessor.
tcmtech also provided a couple. Re-read his post!
11/04/2014 11:31 PM
Maybe you could read a book with your boy.
11/05/2014 10:22 AM
You can get a faster laptop for about $300 at BestBuy. They get rid of the older systems to make way for the newer systems and slash the prices quite a bit. You might also be able to get a refurbished system from UBID cheap, just watch what you want to spend and subtract the shipping costs from that. I've purchased 3 different computers through UBID and all of them worked fine. One I had to assemble myself but all the parts were there.
Good Answers: 119
11/04/2014 10:23 PM
I recommend you buy a more up to date computer for viewing HD movies.
That old OptiPlex is mostly good as a boat anchor.
11/04/2014 11:51 PM
If these are online check to see if tabs are opening up to ad sites (close tabs) - happens first few minutes of shows on "coke & popcorn" for example. These are usually adobe flash. Close all unnecessary services - download "what's running". Be sure your VLC is latest version. Make sure to install latest drivers for display card. As mentioned cooling and better card will do it.
11/05/2014 10:05 AM
OK Sir,
Thanks for your suggestion's. i will apply
11/10/2014 11:40 PM
Is the graphics engine firmware/driver updated?
http://www.intel.com/Assets/PDF/whitepaper/313207.pdf
Register to Reply 12 comments
ahmadarshad (2); dkwarner (1); Doorman (1); Hooker (1); Janissaries (1); jdsighter (1); Kris (1); lyn (2); pavs (1); tcmtech (1)
