(1) colour:
This is a basic parameter, different colors used in different occasions.
According to the color can be divided into seven types of monochrome, color,
full-color single point control three.Monochromatic is a single color, can not
be changed. Connect the power can work. Colorful is the whole string module can
only be the same color, can realize single module of different color, in simple
terms is the only all modules at the same time can only achieve the same color,
different time can change between seven kinds of color. Full color single point
that can control to every module of color, when achieving a certain degree can
display pictures and video effects in the module number. Colorful and full color
single point to add control system can achieve the effect, we in the control
system are introduced in detail in the chapter of control system selection and
application.
(2) voltage:
This is a very important parameter, the current low voltage module 12V is.
When connected with the power supply and the control system must check accuracy
of voltage value, can electrify,otherwise it will damage the LED module.
(3) the working temperature:
That is to say LED normal working temperature. Usually in between -20 to
+60 DEG C, if the range required relatively high occasions to carry out special
treatment.
(4) emitting angle:
No LED module with lens light angle is mainly composed of LED,LED in
different light angle is also different, generally by themanufacturers to
provide the LED LED module emitting angleangle.
(5) the brightness:
This parameter is an important parameter, the brightness is acomplicated
problem in LED, brightness we usually in the module of LED said is usually the
luminous intensity and lumen degree,usually said luminous intensity in small
power (MCD), in the high power usually said lumen (LM). We say "LED" module
illumination iseach LED illumination addition on the line ah, although not very
accurate, but it can basically meet the requirements, ha ha,personal
opinion!
(6) waterproof grade:
If the outdoor LED module with the words of this parameter is very
important, this ensures that the LED module can be an important index in the
outdoor long-term work can not be. Usually in thesituation of IP65 to achieve
the best waterproof grade of full open
(7) size:
This is relatively simple, is often said of the length and the width ofthe
higher dimensions. (8) the maximum length of a singleconnection:
This parameter we do in large projects more, it means that in aseries of
LED module, a LED module connected to the number of.There is a relationship
between the size of the connection line with LED module. Also according to the
actual situation to make to order.
(8) power:
Power on the LED module and an empirical formula: power LED module level =
single LED power LED number "1.1".
