Previous in Forum: Required PTAW   Next in Forum: Connector vs. Solder
Heating Device for Sealants Needed
07/06/2007 7:28 AM
I need to find a heating device to cure a sealant that will be put on threads of metal fittings. I need something that will process approx 3000 parts/hr. The heating requirements are 3 min at 180~210 F and I'm looking for a minimal footprint. Budget target is $50K. The parts need to be spaced approx 2-3" apart until dry.
Thank you.
Good Answers: 266
Re: Heating Device for Sealants Needed
07/06/2007 8:54 AM
Look to using a conveying curing oven. With temp at 180 - 210 should be able to use lamps.
07/09/2007 12:07 PM
Heating element, infrared, light, induction heating, hot air etc.
You'll need test run to set temp so the part will have enough time heat up before exiting the oven.
Pineapple
08/10/2007 12:21 AM
hi i am with southern stress and i think i can help you with this task. I have electrical ovens that are very well designed for these task. How many parts do you have total? i think we can do this job for less. you may reach me at bc_southern_stress@hotmail.com hopfully i can help with your task or give advice and support. THANK YOU FOR YOUR TIME.
