Previous in Forum: Magnetic Flow Meter   Next in Forum: SMC IP801
18 comments
Probe/Anemometer for Measuring Flow Speed and Direction?
12/01/2014 8:54 PM
Hi,
I'm trying to measure the steady state velocity field behind the wake of a bluff body in the wind tunnel. My uni is equipped with 4-hole cobra probes which is capable of receiving flow within a 45 degree cone of acceptance. As the base of a bluff body dominated with re-circulating flow, cobra probe has difficulty measuring back flows (out of acceptance angle).
So my question is:
- Is there any probe/anemometer that measures the flow speed and flow direction (velocity) at a certain point in space. (capable of measuring back flow also)
- My first thought was the hot wire anemometer, but that only measures the flow speed and not the flow direction, is that right?
Any suggestion will be greatly appreciated, thank you!!
Pathfinder Tags: anemometer bluff fluids
Re: probe/anemometer for measuring flow speed and direction?
12/01/2014 9:32 PM
Can you use a tracer gas and high resolution video?
12/01/2014 9:41 PM
Thank you for your reply!!
I will be using smoke for flow visualisation later. However, it is difficult in getting a numerical value for the velocity field using this method, especially if I want to measure the velocity of a slice of the mid plane. I will be using PIV in the water channel, however, the reynolds number achieved in the water channel will be significantly lower.
12/01/2014 9:46 PM
12/01/2014 10:35 PM
Thanks for the suggestion.
My fault for not clarifying. I need something that has high spatial resolution. My bluff body, which is a 1/15th scaled model of a freight train wagon is about 1000mm X 171mm X 438mm (LWH). So I really need something really small such as a cobra probe or hot wire anemometer in order to measure flow velocity at various spatial points at fine increments behind the model.
Cobra probe was great for the most part until it comes to recirculating flows.
Good Answers: 137
12/02/2014 5:42 AM
You're right that hot wire type doesn't tell you direction, if that's any help.
Good Answers: 11
12/02/2014 6:01 AM
At what velocities is your rig supposed to run? At higher velocities you design to run your rig, you may use IR imaging. Velocities have relationship to pressure and pressure of a medium fluid relates to temperature.
A temperature signature could be used to analyze your velocities, any point of your bluff body you like to focus your concerns to.
12/02/2014 7:18 PM
My wind tunnel is running at 30m/s. What speed will I need for IR imaging? Cheers
Good Answers: 11
12/07/2014 6:28 AM
Ahhmmmsubsonic~supersonic, probably.
Good Answers: 445
Re: Probe/Anemometer For Measuring Flow Speed And Direction?
12/02/2014 11:56 AM
Try a pitot tube, static tube combination, you can position it anyway you want as long as the static tube opening is at right angles to the flow. A hot wire anemometer has to be re-calibrated for its enclosure if it's in anything other than free space
Good Answers: 137
12/02/2014 2:19 PM
Don't know about "A hot wire anemometer has to be re-calibrated for its enclosure if it's in anything other than free space". What sort of recalibration?
A big advantage of a thermal type flowmeter (velocity x pipe area) is it doesn't need correction for gas temperature and pressure, unlike say a ΔP type meter. It's often called a thermal mass flowmeter.
12/02/2014 8:22 PM
I don't know if you can get one small enough, but ultrasonic anemometers can measure speed and direction.
http://www.ammonit.com/en/products/sensors/ultrasonic-anemometers
12/02/2014 9:38 PM
Hey guys, thanks a lot for all the inputs so far!! really appreciate it.
Some one suggested me looking into Omniprobe: http://www.aeroprobe.com/probes/view/omniprobes
It has an acceptance range of up to 150degree. I am starting to look into that, the question now is if it comes in a small enough size.
Is anyone here familiar with Omniprobe's operation?
12/02/2014 10:39 PM
That looks like a great solution. According to the pdf, the tips are available down to 1.6mm diameter so that would definitely be small enough for what you want to do.
You need to be able to measure 12 pressures simultaneously or in quick succession. Or maybe you buy the complete thing that does all of that. I can see it being quite expensive though. Is the Uni willing to spend some money on this?
Frankston
12/03/2014 8:21 PM
I think the Omniprobe comes with its data acquisition system. We have pressure measuring transducers ourselves which has 128 channels, so we can also use that to hook up the 12 pressure taps.
But yea, expensive is definitely the first thing that came to mind. We to have commercial funding on this project, so we will look into it. But we might attempt to make something similar in our workshop and calibrate it ourselves.
12/02/2014 11:28 PM
http://www.meacon.co.za/Weather%20Instrumentation/weather/principleofoperation.htm
Interesting!
Good Answers: 25
12/03/2014 1:10 AM
Try these guys:
www.kulite.com/products.asp?p=4-0
We used a LOT of their products in wind tunnels when I was in the aerospace business.
Re: Probe/Anemometer for Measuring Flow Speed and Direction?
12/03/2014 2:12 PM
You may want to look at a Shortridge ADM870
United States - US - Statue of Liberty - How's it going?
12/05/2014 5:54 PM
Do you know anyone with CFD software?
You could input the measured vales and let the CFD calculate the rest.
Have you tried a 5 or 7 hole probe?
If you can't explain it simply, you don't understand it well enough. AE
Register to Reply 18 comments
Codemaster (2); Ed Watts (1); Frankston (1); harley (1); HeHound (1); IdeaSmith (1); lyn (1); MUfluid (5); Noudge79 (2); nvirciglio (1); RAMConsult (1); Rixter (1)
