Previous in Forum: Earth's Magnetic Field   Next in Forum: Uni Directional & Bidirectional on Load Tapchanger
BHEL Frame 6 Machine Generator Tooth Temperature High
12/06/2014 1:07 AM
What is the inference one can draw if the Generator tooth temperature runs significantly higher than any other temperature parameters in a BHEL Frame 6 Gas Turbine Generator?
Good Answers: 444
Re: BHEL Frame 6 Machine Generator Tooth Temperature High
12/06/2014 10:29 AM
Good interview question! How did you respond to it? Hint; your interviewer was determining how much you understood about the GCC (Generator Capability Curve).
12/07/2014 5:05 AM
Surprised to see such customer specific questions raised in a wider CR4 site. You should approach BHEL directly and they will attend to the problem- no need for you to analyze and do R&D on it.
05/29/2015 4:20 AM
_________________________
Teeth Whitening Machine
Register to Reply 3 comments
RAMConsult (1); wfsjjh (1); xyz (1)
