Previous in Forum: 99 Ford Escort Automatic Transmission Won't Move   Next in Forum: Is This Really a Good Idea?
38 comments
1998 Chevy Cavalier. Is the Anti-Theft Preventing My Car from Starting?
12/18/2014 9:12 AM
I have a 1998 Chevrolet Cavalier coupe, 2.4 engine. Recently, I had a brake light put in and as soon as the guy put it in, my car refused to start. They key goes right in, the lights turn on. Everything else is normal. But the anti-theft light is solid on and will not go out. They said they didn't know what happened and pushed my car out of the shop. I had it towed.
Now the other mechanic is saying that the ignition cylinder should be replaced with the keys and that will fix the anti-theft system. But he is charging nearly $500 for that. I do not know what happened as my car has always started right up. How could a brake light replacement trigger the anti-theft? Is that possible?
Is there any way to find out what happened, and is it entirely necessary to put a new ignition cylinder and key set in to fix this? I am nearly out of money from having it towed around and I'm getting nowhere. Please help.
Re: 1998 Chevy Cavalier. Is the Anti-theft preventing my car from starting?
12/18/2014 9:15 AM
12/18/2014 9:55 AM
Are you certain that, at the first crooked crummy car repair shop, you received the correct key when you picked up your car?
Wouldn't be the first time keys at a repair shop got mixed up, and accounts for your description of the issue.
12/18/2014 10:01 AM
On many cars the anti-theft system is tied in the light circuit, that's how thieves disable the system, they just break out a tail light....That common knowledge makes the anti-theft system useless, except to annoy the owner at times.....I would bypass this useless system...
http://www.cargurus.com/Cars/Discussion-t2548_ds38504
12/18/2014 11:08 AM
Thank you.. I wasn't aware that the light circuit is tied into that theft system. It makes perfect sense now! Your answer was great, thank you so much.
Good Answers: 137
12/20/2014 5:06 AM
Interesting. I'd not heard of that, and it seems a weird system. It was a brake light bulb that was changed, not a tail light, but I suppose the mechanic could have disturbed something. Worth checking all the lights anyway.
Re: 1998 Chevy Cavalier. Is the Anti-Theft Preventing My Car from Starting?
12/18/2014 10:37 AM
I know that CR4 has become a mecca for Cavalier problems. I still find it weird that anyone would ask on a public forum how to defeat, reset, remove any anti-theft system.
Contact a reputable repair shop or dealership about this . Bring your ownership paperwork with you. You may have to have a stolen property check with the police performed, too. If $500 is too much to spend for this nearly seventeen year old car (an understandable conclusion) then junk the car.
12/18/2014 10:41 AM
We can only take pity on someone who would attempt to steal a Cavalier....with the certain knowledge that in the end they get what they deserve....
12/18/2014 11:10 AM
I own the car, red. I've owned it for years and never had this problem before.
Good Answers: 266
12/18/2014 10:52 AM
Cavalier used a couple of anti theft systems. There should be instruction to reset which ever one you have in the owners manual. The main one calls for you to attempt to start the car for 10 seconds then let ignition set in the on position for 10 minute the light should go out. Some say it may take several tries so have battery charger handy.
I would though take it some where and have it by passed. The list of problems with their anti theft systems is end less. Sort of like the list of problems we see with the cavaliers.
12/18/2014 11:23 AM
pass. good luck
Good Answers: 151
12/18/2014 11:49 AM
I assume that your car has the GM Pass-lock system and your key has a small chip embedded in it. Actually the chip is just a resistor which is read by the body control module. I had the same problem with my 99 Pontiac. Do not let anyone rip you off for a new ignition switch. The problem is not there. Probably when your brake lights were worked on, the wiring under the dash was disturbed.
For a good explanation of the system visit www.newrockies.com. They sell the necessary components to completely bypass the whole thing, if that's the way you want to go. I installed their product (an electronic module) and never had another problem since.
And ,if you bypass the security system you may get lucky, and someone will steal your Cavalier
12/18/2014 12:40 PM
these systems and entire cars are such piles!. I just read that website, that is the answer if you want one of these cars. reminds me of the old Fram oil filter commercial where the guy says, " you can pay me now or you can pay me later"
12/18/2014 1:34 PM
Ahah! Another victim of the Dark Side of the Force!
Good moaning!
12/18/2014 5:38 PM
Really? You're worried about someone stealing your 1998 Cavalier?
I would be more worried about someone stealing your garbage can.
I would be willing to bet that you take most any 1998 Caviar into the worst part of any town you can find walk away from it with the doors unlocked, windows down, keys in the ignition and running (if it will stay running long enough to walk away of course) and come back hours later and it would likely still be there. (probably not running though)
12/18/2014 6:10 PM
2 points here.
1) I am not worried about someone stealing my car. I realize that I only paid $1200 for it years ago and the anti-theft system has made it impossible to start. Nothing else is wrong with it mechanically or functionally. The "anti-theft" feature is default and was made into the car. I did not have it installed myself.
2) I need this car to get to and from school/work. It is paid for and gets me around town just fine (usually). This problem came up recently and I am trying to find a way to get it working again without spending half the price I paid for it just to get it repaired! (that it's not even worth to spend into the car to begin with).
If you have any other comments to say to me because I don't own a f*cking Audi or BMW, then shoot away. But I don't care for comments that keep accusing me of stealing my own damn car and/or someone else stealing it. That is NOT the point. I came here thinking someone could help me figure out how to undo this so that I won't miss too many days of work and get f*cking fired. The end.
Thanks to just a few of the amazingly helpful members above who actually tried to help.. they gave me useful advice to follow and I'll have it fixed soon enough. (Thanks to them). Guys like you are pointless and your comments to me are a waste of time. Thanks anyway, tcm.
12/18/2014 6:17 PM
forgive TCMTECK, you really have no idea just how often we get starting issues on this model of car, its routine around here to bash this vehicle.I'm sure he didn't mean to offend. as already noted the net is loaded with info on this. best of luck
12/18/2014 10:51 PM
Let's get past them. If indeed it is the lock cylinder causing the problem it's not unusual. There are two small white wires that go up in the column that twist every time the ignition lock cylinder is turned and it's not uncommen for these wires to evenually break. When you put the key in the lock cylinder the chip or resister in the key completes the circuit for these wires back to the passlock module. If you measure the resister in the key then you can find a resister of equal value and just solder it in at the base of the column where the two white wires come out and presto, you have "fooled" the passlock system.
Now you don't have to spend $500 on a new lock cylinder, just tear apart some old piece of dead electronics and find a resister that matches your key "chip".
Jesus hung out with undesirable people because they needed help the most, so try not to be too harsh towards these guys. They really mean well, they just don't know how to say it.
12/19/2014 10:37 PM
This is the best answer on this forum. You can identify this system if there is an electrode present on both sides of the key shank that is separated from the shank with an insulating plastic insert. This system key contains a resistor of a value that was stored in the car's computer the first time the car was started at the factory. I think there is a +/- 5 ohm tolerance that the computer will recognize. Once the car starts, the anti-theft system is bypassed. The wires in the column for the anti-theft system are very tiny, and after a while, they will break due to stress fracturing.
Sometimes cars break down by causes that are totally unrelated to the condition that was previously addressed. Anyone who has worked on cars a lot can attest to this. So, yeah, replacing the light bulb, although unrelated to the anti-theft, would not cause the problem, but the anti-theft could have failed at that time. Some folks refer this as "coincidence".
I used to own a 96 Buick that contained this system. When it went South, the loose wires would make connection or not, depending on whether the wire ends were in contact with each other at the time. Sometimes I could smack the column to get the auto to start. It was perplexing because the car was my Wife's ride, and when she was unhappy, I was unhappy. I putzed with this car for weeks. So I took the column apart and saw these tiny wires. I could have attempted a repair, but figured it would break again sometime down the road, probably miles from the house. So I measured the resistance across the key electrodes, picked up a resister of the same value at Radio Shack and spliced it into the wiring under the column. Never had that problem again. No, I did not worry about someone stealing this dog. There is a lot to be said for a car that doubles it's value every time you fill it with gas!
My kids had Cavaliers, and I had no problem working on these cars. A lot easier than other cars I've owned. I thought they were pretty decent cars. Good entry level rides. And this coming from a Ford guy.
Good luck, and don't let those pompous BMW, VW, Porsche, and Audi owners get to you. You'll note that these are all German marques. Guess they're still sore from getting their butts kicked.
Semper Fi. Oorah!
12/19/2014 6:30 AM
If it truly is the anti-theft system try a local locksmith, they deal with these problems all of the time. And they have (most of them do) the scanners to check out the problem, if they can't find the issue they most likely can offer a reference to a electrical repair shop to trace the problem. As it is a common issue on these cars and several other models to have security light issues. Vans and pickups are another big problem with security light issues. Good luck
12/19/2014 8:26 AM
I bought/own a 2003 Chevy Cavalier. Purchased it "brand new" from the dealership in late-2003 (at a great price .. I must add). The odometer just recently turned over 217,000 miles !! :)
Sure ... I've had the "normal/typical" problems (i.e, various parts replacement, spot paint/rust issues, etc.), but overall .... I have been extremely pleased with this GM product. I am hoping to get another 50,000 miles out of it.
I am a firm believer that regular maintenance and/or service was the key to it's longevity & performance.
12/19/2014 8:29 AM
thats a first!!
Good Answers: 88
12/19/2014 9:49 AM
We don't doubt your positive experiences, but the unbelievable number of requests in this forum for help because the "beast" won't start, should be obvious it has turned the whole concept to a joke between us members, no personal offense of course. Actually we don't believe its a bad car, not the worst anyway. But it is obviously a major setback to what you were used to in the States. By the way, that kind of build quality, apart for a couple of manufacturers that also follow, just more slowly, is becoming mainstream here in Europe, and it is not justified by any rational reasoning, just a blurred argument like "If a product lasts for TOO (?) long, what will industries sell?" The solution was to make products self destruct. Funny thing is that the same people that use this argument are also self proclaimed "environmentally aware". How those two combine, it beats me. (LOL) S.M.
12/19/2014 10:18 AM
I agree that the Cavalier is the but of many jokes here due to the large number of seemingly clueless people that have asked inane requests here about this model of vehicle. [I still don't understand how this started. CR4 is not a Chevy, Cavalier, DIY automotive forum but an engineering forum.]
Getting back to engineering, you touch upon a common misconception that vehicles have planned obsolescence to keep companies alive. This is not true. Nothing lasts forever. Metal fatigue, corrosion, and a myriad of other things will cause a car to eventually fall apart. Methodical maintenance will certainly extend the lifetime of a vehicle. To make a cost competitive vehicle an engineer should weigh the anticipated Mean Time Between Failure of the variety of parts and either make the short lived wearing parts (brake pads, lamps, wiper blades, etc.) relatively easy to replace or design the parts MTBF to just barely exceed the expected lifetime the market expects for that price of a vehicle.
12/19/2014 11:22 AM
You don't believe in planned obsolescence? Have you forgotten Volkswagen and Audi products from the 1980's?
12/19/2014 1:09 PM
Clearly the obsolescence is real. I do not believe it is planned. At least it is not planned by the car designers. One can make the argument that the car regulators deal with planned obsolescence.
Good Answers: 88
12/19/2014 11:25 AM
The sad thing is that if you overcome your... good will attitude and see things more suspiciously, having of course some general material and design knowledge, combined with some global economics (not economics you see on TV of course) you'll be surprised. You will see seeds of self destruction, not programmed obsolescence, that's too soft of a term behind EVERY single useful life defining detail, on most today products. Not saying you will be happier to know about it and where it eventually leads. S.M.
Good Answers: 104
12/19/2014 11:42 AM
Sounds like you've encountered 'value engineering' also?
Good Answers: 88
12/19/2014 1:05 PM
Never heard of it before, had to look it up, it seems like an idea conceived in US at difficult, war times, and forgotten not long after that, an "alternative" was there. I'm talking about modern times, where the "alternative" bubble colapses worldwide. But aren't we getting just a... bit off-topic? (lol) S.M.
12/19/2014 11:18 AM
Sounds like LadyX got to the same point I did a few weeks ago with replies!!! She'll get past it, though, just like I did!!
12/19/2014 7:36 PM
If you hang around here long enough you will find that TCMTECH is very helpful. If you re-read his post you will see that he doesn't criticize you in any way. The car, however, now that is the target of much derision and fun. I, for one hope it continues as it gives me a laugh. Would you rather a joke at the expense of an inanimate object OR at the expense of the people who post?
Jim
Good Answers: 137
12/20/2014 5:10 AM
Amusing answer! Please let us know whether and how you got the problem fixed.
Good Answers: 88
12/18/2014 7:21 PM
I have to disagree with cavalier ranting just this once. The anti theft system in question must be one of the most successful in the industry. Thieves informed that not even the owner can start it and seeks for solutions in public forums, ought to be totally discouraged to steal it. S.M.
12/19/2014 3:40 AM
Hello, I am a 70 year old retired person and I must object to the negative remarks made about the 1998 Chevy Cavalier. I currently drive a 1999 Chevy Cavalier which I bought new in September of 1998. It has been very reliable and has never left me stranded anywhere. I have only had minor repairs in sixteen years of ownership. When I bought this car new, it was a recommended buy from Consumer Reports. It also had 90% North American content. Frank Neal
Frank Neal
12/19/2014 7:55 AM
Go to automotive forums.com Search site they have information on how to use a resistor to bypass Anti-Theft on older Chevy's.
12/19/2014 10:29 AM
Could be worse, you could own and older BMW or Audi.....
I finally traded my '90 750iL for a Tractor..... Thankya Geezus!
Actually, your question is more appropriate for a GM forum and you would be better served there.
12/19/2014 4:18 PM
All cars seem to have problems, some more than others.....I'm still trying to deal with the fact that my Mustang has a live grenade planted in the steering wheel that could go off at any time....and the dealer's answer is to replace it with the same thing....Takata has done more to add to the distrust of manufacturers than anybody I can remember...
Me so sorry...
http://www.jsonline.com/business/national/takata-quality-chief-shuns-national-air-bag-recall67ce8ba59b5a4238b67597140c59de78-283348131.html
12/19/2014 11:13 PM
turn on the ignition and wait 10/15 minutes and try and start the car and if it starts the anti theft is at fault
10/17/2018 5:26 PM
I don't know if anyone still reads this thread, but I have the same issue with a twist. The anti-theft flashes and I can wait the 10 min until the light goes solid and it starts right up BUT it ONLY happens when it is cold out (around 50 degrees or less). I was living in Florida where this was rarely an issue, but now that I live in Texas it has happened all week so far. :( Waiting the 10 min in the morning is not a big deal, I just leave for work earlier, but leaving work 10 min later is a huge deal as it can add 30-45 to my commute. I want to just permanently disable this feature (20 years old, 210k miles) by "snipping" the wire and capping it as someone suggested. I can't afford to put any money into this car so the dealer is out. Where/how can I snip the wire controlling the anti-theft? Is there a video? I'm pretty handy and could probably do it myself with the proper guidance. Thank you!! :)
Register to Reply 38 comments
autotechnocracy (1); bigg (1); Codemaster (2); corbinstein (1); Crabtree (1); Doorman (1); drdave (1); Fredski (4); gringogreg (1); JIMRAT (1); knarfman (1); LadyX (3); LOCKDUKE (1); lyn (1); motorman (1); nuccore (1); ozzb (1); redfred (3); rhandwor (1); roeblinggrid (2); SimpleMind (4); SolarEagle (3); tcmtech (1); txmomoftwo (1)
