Previous in Forum: SF6 circuit breakers   Next in Forum: Generator synchronising
3 phase power quality analyzer
07/07/2007 5:07 PM
Which is the cheapest good quality 3 phase power quality analyzer available.
Re: 3 phase power quality analyzer
07/08/2007 5:42 AM
Too many contradictions in the question - tell us what you what to measure
just basic like KVA, KVARs, PF and voltage, per period
or waveform and harmonics displays analysis?
07/08/2007 2:52 PM
Thankyou for your reply.
I am looking for something similar to Fluke 43b or Tes 3600 http://tes.com.tw/kwe.htm
KVA, KVR, KWH, current Harmonics waveform with data logging.
07/09/2007 12:43 AM
Look at Fluke 1735
07/09/2007 10:07 AM
Renting when you need it is the least expensive.
there are 3 or 4 rental companies with power quality test sets
Alternatives:
http://www.powersourcing.com/
http://www.industrialbuyersguide.com/
07/12/2007 6:39 AM
Cheap is nice,
If you want the best, check out Elspec power quality analyzers.
You can log all power parameters continuously onboard for a year+ at 1,024 samples per cycle resolution.
The Elspec G4400 Power Quality Data Center allows engineers to determine if the fault was caused on the Utility side, or if the fault was caused by the facility; faulty equipment, transients, harmonics or switching events.
http://www.elspec-ltd.com/default.asp?V_DOC_ID=2239
You can also check the PPQ-306 Portable Power Quality Analyzer at:
http://www.elspec-ltd.com/default.asp?V_DOC_ID=1867
