i have a 1991 toyota camery,what its doing is running just fine in low gear (automatic trans) and when it hits second gear it just goes flat,loses all power but , keeps slowly keeps picking up speed. at other times it shifts just fine with plenty of power threw out all gears. mind you only second gear is the one it fall on its face with,3rd 4th are fine . when it falls on its face 4th or overdrive don't work. ive adjusted the detent cable and it made no difference. could it possible be the overdrive switch on the shifter?
