Previous in Forum: Compressor Work in Brayton Cycle   Next in Forum: Bread Oven Chimney
Indonesia - Member - New Member
Cast Steel Material Could Be Weld?
01/18/2015 3:24 AM
We have to buy fully welded ball valve 28" (#300 & #600) based on our client owner requirement.
Based on our vendor information, big valve fully welded valve should be using Forging Material (Ex. A105N) other than Casting (A216) material.
Is it true?
Is cast material technically could not be welded?
I already check at ASME B31.3 that A216 WCB material belong to P No.1 same as A105, there's no different between them
Pathfinder Tags: Cast Steel A216 welding
Re: Cast steel material could be weld?
01/18/2015 7:57 AM
it can be, yes
01/18/2015 8:42 AM
Good Answers: 11
01/18/2015 9:25 AM
It is possible for welding but definitely not recommended for strength concerns. Cast Iron/steel are brittle usually goes with high carbon content. Localized heat in the weld will result to residual stress on the spot and surrounding material, thus consequent to breaking and material fatigue when subject to external forces or pressure.
It is a bad idea. But, try welding sample cast iron and you will see how it is.
Re: Cast Steel Material Could Be Weld?
01/19/2015 12:04 AM
I used to 'upgrade' cast ss valve bodies used in submarine service, process was grind out imperfect areas, preheat, tig weld fill, post heat to stress relieve, pack in vermiculite for cool down (appx. 16 hrs).
01/19/2015 3:11 AM
The main problem encountered is that inexperienced welders have made a mess and the reputation of some metals has worsened. I have never had problems with this grade of steel either as cast or a forging. The correct weld procedures however must be followed as in any welding job. Keep the inexperienced welders away from it
Good Answers: 34
01/19/2015 7:08 AM
Yes there are differents ,yes is true and yes this material could be welded.
Avatar Indo you have to check ASTM 216/216M "Specification for steel castings, carbon, Suitable for fusion welding for High temperature service"
An extract (ASTM SA 216/SA 216M):
Repair by Welding
10.1 Repairs shall be made using procedures and
welders qualified under ASME Section IX.
10.2 Weld repairs shall be inspected to the same
quality standards that are used to inspect the castings.
When castings are produced with Supplementary
Requirement S4 specified, weld repairs shall be inspected
by magnetic particle examination to the same standards
that are used to inspect the castings. When castings are
produced with Supplementary Requirement S5 specified,
weld repairs on castings that have leaked on hydrostatic
test, or on castings in which the depth of any cavity
prepared for repair welding exceeds 20% of the wall
thickness or 1 in. [25 mm], whichever is smaller, or on
castings in which any cavity prepared for welding is
greater than approximately 10 in.2 [65 cm2], shall be
radiographed to the same standards that are used to inspect
the castings.
10.3 Castings containing any repair weld that exceeds
20% of the wall thickness or 1 in. [25 mm], whichever
is smaller, or that exceeds approximately 10 in.2 [65
cm2] in area, or that was made to correct hydrostatic
test defects, shall be stress relieved or heat-treated after
welding. This mandatory stress relief or heat-treatment
shall be in accordance with the procedure qualification
used.
Copyright ASMERepair by Welding
the castings.
used.
To determine the P and F numbers read
ASME IX
QW 420 and 430.
WP
Good Answers: 103
02/11/2015 1:34 AM
It is interesting, since as far as I am aware, the larger bores use A216, due to the difficulties and the costs in forging large pieces. The forging scores over the casting due to only integrity (defect prone -pin hole etc and other casting defects) and no other technical reason I can think of.
Bad reputation of castings are due to,
1. Most of the casting standards are lenient in composition, heat treatment and inspection.
2. The control exercised by the foundries, due to lack of knowledge or economics, in both composition and heat treatments. Due to this the quality factor on general castings (derating factor) is specified in the ASME/VIII which with the proper NDE and testing could be again made 100%.
However since these additional NDE requirements are not mandatory (supplementary requirements) would be enforced only if specified in specific purchase orders. These (Radiography, LPI, MPI etc) ensures the structural rigidity.
But there is another factor which you must bear in mind. The forgings are usually two halves, joined by flange or welding. But castings are usually single piece.
Register to Reply 7 comments
Fredski (2); geraldpaxton (1); minmi (1); Noudge79 (1); sb (1); Whitephone (1)
