I bought a couple of solid state timers with the intention of making a variable duty cycle pulse and delay circuit that was supposed to repeat. The concept was supposed to mimic a pair of timers in a PLC program. What I didn't catch was that to reset the timers, I had to remove power (to both timers).
So, after careful consideration, I realized that I could make it work if the output of the delay timer (always longer than the pulse timer) was faster than the motion of the normally closed relay contacts. It works with a large enough relay. Now I have to switch to a smaller relay and I'm wanting to add just a little bit of delay to the coil as power is initially applied. My intuition says that I need a series capacitor and a parallel resistor to do this. The question is what should my target values be.
Everything is running on 120 VAC, 60 Hz. The solid state timer outputs are optically isolated from the inputs and only fire at a zero crossover. If this isn't enough information, I can include the diagram. But I figured that with this description so far, any qualified person would understand what I mean without further detail.
Is it enough information? I'm feeling lazy but if it is too unclear, I can draw it up.
