Previous in Forum: Transformer   Next in Forum: Monorail for DG Set.
Hormonics Blocking
02/04/2015 5:58 AM
What is reason behind to block the hormonics during initial energization of power transformer?
Re: Hormonics Blocking
02/04/2015 7:44 AM
Because Harmonic loses ( distorted frequencies) return through Neutral path into transformer and can damage the neutral connected terminal inside the transformer. It may also cause huge vibro structural abnormal sound in dry type cast resin transformer.
There are no shortcuts on the road to a great experience.
Good Answers: 444
02/04/2015 10:41 AM
To prevent false trips of the transformer's protective relaying.
02/05/2015 12:09 AM
Is it by by-passing OC/SC/EF relays?.
pnaban
Good Answers: 42
02/04/2015 10:31 PM
Can we have fun with the hormonics?
Too much libido?
02/04/2015 10:54 PM
They will if you don't pay them.
02/10/2015 11:53 AM
To prevent nuisance tripping of protective relays of transformer, specially,. transformer differential protection relay.
Manindra.
Manindra
Register to Reply 6 comments
Aseer (1); Brave Sir Robin (1); GW (1); manindra (1); pnaban (1); RAMConsult (1)
