Previous in Forum: Outer Rotor Induction Motors   Next in Forum: Adverse health effect of exposure to electric and magnetic fields
BG
07/10/2007 9:27 AM
Where can I found a DIY circuit diagram to built? I have an 36V Dc input invertor with an 3000W Ac output. I want to monitor the 36Volt battery pack. All I want is at least three lights, say red (indicate the battery pack must be charged), yellow (to indicate that I must start my generator to charge the 36 V battery pack - with a buzzer. This light must come on before the invertor cuts the power) and a green light (indicate that the battery pack have sufficient power). It would be nize to have something to fine tune the voltage needed for each light to work. In that case I could customise it for my setup. I have solar panels to charge the battery pack during the day. The battery pack is built inside a power room and I want my battery monitor inside the house ±10m away.
Regards
Dixon
Good Answers: 52
Re: BG
07/10/2007 10:55 AM
I found a link to a circuit that is identical to what you want, but the voltage of the battery is not the same. The circuit is based on using op amps as comparators, and is quite simple. This circuit should work just fine for you, but you will likely need to change some of the resistor values and the reference voltage to get it to work at 36 volts. You might just be able to use a different reference voltage depending on what voltages the lights need to go on at. A comparator works by comparing two voltages, one is your reference voltage and the other is the one you are measuring. In this circuit you want something to happen at 3 distinct voltages, so you need 3 reference voltages, these are obtained by using resistors to divide the reference voltage. The circuit is really like 3 separate circuits for each voltage measurement. Play around with this circuit on a bread board with some potentiometers for the resistors, its quite simple, and if you don't know electronics its a good one to experiment with.
Reply to Forum Thread
You might be interested in: Battery Holders, Battery and Fuel Cell Components
