Previous in Forum: Balanced Three Phase Delta Circuit Problem   Next in Forum: Circuit Breaker
how to calculate multiplying factor if meter ctr is -/5?
02/26/2015 6:09 AM
hi,
what is the multiplying factor for 3 ph 4 wire kwh meter if line ctr is 1000/1A, ptr 3*240V and meter ctr is -/5 A, ptr is 3*240V?
Re: how to calculate multiplying factor if meter ctr is -/5?
02/27/2015 6:33 PM
Good Answers: 42
03/23/2015 7:52 AM
Let's say the primary current is 1000 A. Then the meter receives 1 A and interprets it as 1000 A.
Now, if CT ratio will be 1000/5 and the primary current will be 1000 A too, the meter receives 5 A and interprets it as 5000 A. So, in this case you have to divide the reading by 5.
Julius
Register to Reply 2 comments
