Previous in Forum: Why is the Radiator Called Radiator?   Next in Forum: Safety Factor in 'ASME DIV.1&2'
Ratio of Wheel Base to the Track Width for an ATV
02/26/2015 11:24 AM
what is the ratio of wheel base to the track width of All terann vehicle (ATV) for better turning of vehicle
Good Answers: 76
Re: ratio of wheel base to the track width for an ATV
02/26/2015 11:55 AM
I think for general stability - torque at the wheels is a factor of wheelbase. And for turning, center of gravity and weight distribution would be factors as well... because you're looking for a static equilibrium.
Bottom-line - I don't think there is a set 'wheelbase to track width' ratio that is used as a basis for design, but rather the ratio is 'derived' as a result of the totality of the design.
02/26/2015 12:37 PM
All 5 of your questions have been homework!
Tips for Posting on CR4:
Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
There are homework cheat sites on the internet. THIS IS NOT ONE OF THEM!
02/26/2015 4:29 PM
Then there are some that just make up their own!
02/26/2015 6:52 PM
You mean, you don't use a tape measure yourself and want a load of anonymous strangers to do it for you, then? No. I won't. Life is too short as it is.
Good moaning!
02/26/2015 8:07 PM
Turning in which direction, pitch or yaw? Very low ratios allow for totally gnarly wheelies.
Brave Sir Robin (1); Crabtree (1); JavaHead (1); lyn (1); Tom_Consulting (1)
