Previous in Forum: Analysis of Producer Gas by ORSAT Analyser   Next in Forum: 108 MTRS of 60MM Dia Round Bar
LNG Flow Simulation Using Hysys
02/28/2015 5:01 AM
I want to build up a simulation interface for a LNG Terminal on hysys 2006 but i cant really figure out which fluid package to be used.The LNG composition is as follow :
  1. C1 93.6 %
  2. C2 6.33 %
  3. C3 0.06 %
  4. i-C4 0.00 %
  5. n-C4 0.00%
  6. i-C5
  7. n-C5
  8. n-5
  9. C6+
  10. Nitrogen 0.01 %
  11. Carbon Dioxide 0.00 %
I have used Peng-Robinson package for my simulation "knowing that it's the recommended one when simulating liquefaction Unit", but i want to make sure If I am on the right path or not !
Thanks in advance for your guidance and advise
Learning is the only thing the mind never exhausts never fears and never regrets
Pathfinder Tags: LNG Hysys
Good Answers: 109
Re: LNG Flow Simulation Using Hysys
03/01/2015 11:47 PM
You are on the right way when you seek training on the software you work with. If you know what is being modeled you just skip the step to ask strangers to do your work.
i
03/02/2015 3:23 PM
Thank you for your confirmation.
Hopefully I reach the level of "Not asking strangers for help".
Everything takes time.
03/04/2015 9:30 PM
It sounds really good, too wonderful!
Register to Reply 3 comments
golddty (1); IdeaSmith (1); Sheva (1)
