Previous in Forum: WiFi Network   Next in Forum: What is the Approx Bay Size for 2000 KVA 11/0.433kV Distribution Transformer
Good Answers: 183
Soft Conservation
03/11/2015 2:08 PM
Hi,I have a problem and hope to get some hints how to solve it.
Here it is:
I have a couple of soft packs I use since several years ( FEA-mechanical/thermal/magnetics/aso, CAD 2D and 3D) and have been informed that they will not be supported any more as download and re-install.
In case of a crash or PC failure I will loose those programs which are important to me.I want to make a HDD clone on an external drive, the problem is can I use it with an other PC ?What should I do to be sure that the external drive with the clone will work properly with the new computer ?Could you recommend a free GOOD clone software ?Thanks
Pathfinder Tags: Clone compatibility
Good Answers: 76
Re: Soft Conservation
03/11/2015 4:02 PM
Seagate DiscWizard is free if your HDD is either a Maxtor or Seagate brand.
http://www.seagate.com/support/downloads/discwizard/?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD
Otherwise, Google it - it appears there are a ton of options out there... just need to do a little research to find what best suits your needs and your hardware and software.
https://www.google.com/?gws_rd=ssl#q=Hard+Drive+Imaging+software
03/11/2015 10:37 PM
Better to make back-ups using a ghosting program onto another hard drive.
http://www.symantec.com/page.jsp?id=ghost
Good luck with your quest.
Good Answers: 183
03/12/2015 4:00 PM
Thank you for hints the problem as I mentioned is NOT to clone but to be sure that the clone will work with an other PC since I was told it is not possible. This is the critical point and I do not find a source to get the right answer, maybe I do not formulate the question the right way.
Register to Reply 3 comments
Brave Sir Robin (1); JavaHead (1); nick name (1)
