TeknologikL Blog
TeknologikL
The blog's owners are constantly searching for the next device to satisfy their ever growing hunger for technology. Media junkies standing on the edge of reality, ready to take the jump.
Previous in Blog: I Pass on the Apple iPad (and You Should Too)   Next in Blog: HDCP Handshakes (Part 1)
Video: Popcorn Hour C-200 Mod - Blu-ray Drive & 3.5" Hard Drive
Posted February 11, 2010 12:00 AM by Kaplin
A few months back, I did a review of a device called the Popcorn Hour and explained how it radically changed my television watching habits. Since then, the Popcorn Hour C-200 has been released and I upgraded my box.
The Popcorn Hour C-200 lets you install a PC Blu-ray drive to use it as a Blu-ray player. The only issue with installing an optical drive into the C-200 is that then there is only enough space to install a 2.5" laptop hard drive instead of a 3.5" desktop hard drive.
The Popcorn Hour itself is plenty large enough to house a desktop hard drive, so it seems odd that it wasn't designed with that capability from the start. Either way, a very simple modification will give you room to install a Blu-ray drive and a 3.5" hard drive, and still have room for the 2.5" laptop hard drive as well.
Networked Media Tank (NMT) users have come up with a few different ways to attach the 3.5" hard drive; I think the way I chose makes the most sense and was first posted by michaelr64.
I recoded a video with the help of Sharkles and SavvyExacta showing the exact steps needed to complete the modification, but I'll include step-by-step instructions below as well.
Click Here For Popcorn Hour Modification Step-by-Step Video
  1. Open Popcorn Hour C-200 and unscrew four (4) screws to remove optical drive chassis.
  2. Remove the plugs from the rear-end of the optical drive bay.
  3. Open the two wire clips and remove them so the wires can be moved out of the way.
  4. Unscrew plastic piece/faceplate from the optical drive chassis and remove.
  5. Insert Blu-ray drive into chassis and screw them together. Only screw in two screws on the right side of drive when looking at it. The screws on the left side will be added later.
  6. Drill through the holes in the U-bracket to make them big enough for computer screws. (Should be only slightly larger than current holes)
  7. Attach the U-bracket to left side of hard drive when looking at hard drive from the back (the side with connections). Use two screws and have the U-bracket positioned so it is flush with the front side of the hard drive.
  8. Attach the other side of the U-bracket to the open side of the optical drive, so the hard drive and Blu-ray drive are one "unit" connected by the U-bracket.
  9. Fit the Blu-ray drive chassis with 3.5" hard drive attached into the Popcorn Hour C-200 so that Blu-ray drive is lined up with faceplate. Attach two screws to the right side of the Blu-ray chassis when looking at PCH from the front.
  10. Hard drive should be held up on the other side by the wires and sheathing. If you feel the need, you can build a little foam support to keep that side balanced.
  11. The SATA wire will not reach back to the hard drive unless the sheathing that holds all the wires together is cut a bit. Use a scissors or knife to cut the sheathing about an inch to give the SATA wire enough leeway to reach to the hard drive. DO NOT CUT THE CABLES THEMSELVES.
After you boot-up the Popcorn Hour, you will need to format the hard drive and install the NMT apps from the Maintenance section of the Settings page.
Also before using the optical drive, you will need to set the region code for the drive. The Blu-ray region was already set to Region A (USA), but the DVD region needed to be set before it would allow playback.
Blu-ray Disc Region Setting:
  1. Go into Setup (no need to put a BluRay into the drive)
  2. Press the following buttons: "SLOW, 1, 6, 6, 3" on your remote
  3. A popup appears; on the remote, use the number keys to select the region you need.
Blu-ray Regions
1 - Region A (most North, Central and South American and Southeast Asian countries plus Taiwan, Hong Kong, Japan, and Korea)
2 - Region B (most European, African, and southwest Asian countries plus Australia and New Zealand)
3 - Region C (remaining central and south Asian countries, as well as China and Russia)
DVD Region Setting:
  1. Insert a DVD Disc that has the Region you want to select; if the Region is not the same as the Disc, it won't work!
  2. Go into the Setup Page and press the following buttons on your remote: "SLOW, 1, 6, 8, 3 4).
  3. Now, a popup appears; on the remote use the number for the region you want to select.
DVD Regions
1 - Canada, United States and territories, Bermuda
2 - Western Europe, incl. United Kingdom and Central Europe; Western Asia, including Iran, Israel, Turkey, and Egypt; Japan, South Africa, Swaziland, Lesotho; French overseas territories
3 - Southeast Asia, South Korea, Taiwan, Hong Kong, Macau
4 - Mexico, Central and South America, the Caribbean, Australia, New Zealand, and Oceania
5 - Ukraine, Belarus, Russia; the Continent of Africa, excluding Egypt, South Africa, Swaziland, and Lesotho; Central and South Asia, Mongolia, North Korea.
6 - People's Republic of China, Hong Kong
More Info:
NMT Wiki - C-200 Modding
C200 with BD Rom and 3,5'' HDD
CR4 Video - Popcorn Hour C-200 Mod - Blu-ray Drive & 3.5 Hard Drive
