Aerospace Blog Blog
Aerospace Blog
Previous in Blog: How Much Safety?   Next in Blog: The Gun-Smash and Atlas Series: A Senior Design Project (Part 2)
11 comments
The Gun-Smash and Atlas Series: A Senior Design Project (Part 1)
Posted June 02, 2010 12:00 AM by moorec74
In order to graduate from RPI, each engineering student must participate in a senior Capstone design project. As I described in a previous blog entry, I was a member of a 9-person team designing a two-craft helicopter system to compete in this year's AHS RFP. I'll break down our design of the Gun-Smash helicopter in Part 1 here, and describe our Atlas lifting system in Part 2.
Design Philosophy
The mission requirements for this project were that two rotorcraft vehicles needed to operate as a system such that they could carry 75% more payload than either could accomplish alone. They needed to deliver a payload 100 nautical miles from the starting location, with a 10-miute hover period mid-mission. Both vehicles then needed to return to the initial location. The system needed to accommodate ISO containers, military vehicles, and other large machinery.
A brief aircraft configuration study (more detailed in another blog) was performed in order to weigh our various options. We compared the tandem rotor design to the traditional SMRTR (single main rotor tail rotor) method, as we felt these would be the best potentials for our goal. Using MATLAB code to compute estimated numbers, the tandem configuration was deemed a better option due to the lesser power loss.
Rotor and Hub
As a foundation for the design, we chose to use Boeing's CH-47 Chinook. It consists of two rotors in tandem, rotating in opposite directions to cancel out the moments caused by the blades. In addition, we integrated the use of flex beam technology, which is mechanically simpler than the current design; fewer parts mean less potential of failure. We suggested they be manufactured from fiberglass rather than carbon fiber based on the needs of the craft.
In order to carry a larger payload, more lift is necessary. One of the ways we accomplished this was by using new airfoils with updated blade twist geometry. After significant research, we concluded that the use of the VR-12 and VR-14 airfoils would increase the performance standards of the current VR-7 and VR-8 design. We allowed for 11 degrees of twist from root to tip, with 18-degree twisting outboard to 7-degrees at the tip.
Another aspect we focused on were some solidity factors. We decided not to increase the rotor diameter. By leaving this dimension unchanged, we did not modify the necessary space to store one of the craft. We did increase the chord of the blade form 2.5 feet to 3.5 feet to lower the lead-lag moment on the rotor. Initially, we planned on integrating 4 blades into each hub and rotor assembly. After more careful thought and consideration, however, we found that the added weight was unproductive and less efficient than the 3-blade design.
Engine and Transmission
Many modifications were made to the Chinook design to reach the engine and transmission assembly of the final Gun-Smash vehicle. We upgraded to two Allison AE1107C engines, which are currently used in the V-22 Osprey. It's high output, with a capacity of 4 gallons per engine. The oil system consists of a tank, pump, cooler, particle detector, redundant filtration, and a separator. Aluminum was selected for the casing since it is good with heat, lightweight, and inexpensive. The gear stock, however, was improved to Inconel 625 since it is very tough and forms a layer of passivation at the surface. A dry sump system was chosen for lubrication.
Fuselage and Landing Gear
We proposed a change to the fuselage of the helicopter and intended to model it after the S-64 Skycrane. We realized quite quickly, however, that this was not as feasible as we had anticipated. By removing a large portion of the body, we were also detracting from its utility for other purposes. The only major change from the Chinook was the fore and aft hooks, which were reinforced for the added payload.
Join me next time for details on the Atlas and for other details about the rotorcraft system!
Good Answers: 15
Re: The Gun-Smash and Atlas Series: A Senior Design Project (Part 1)
06/02/2010 9:27 AM
On the rotor tips, did you do any modifications there?
I have read that on aircraft, the little winglets on the tips of the wings give added lift, also they limit the amount of air that washes off the tip of the wing, and the turbalance caused from the movement of the wing through the air.
Wouldn't this approach also aid in the same principals with helicopter blades as aircraft wings, but the blade tips would almost be trying to push thru the turbalance from the last blade pass?
Just a curious thought.
06/02/2010 1:03 PM
I have read that on aircraft, the little winglets on the tips of the wings give added lift, also they limit the amount of air that washes off the tip of the wing, and the turbulence caused from the movement of the wing through the air.
I have heard eliminate turbulence on fixed wing air craft , but suspect there may be problems on the rotary wing.
p911
06/02/2010 1:06 PM
What type of performance did you gain? lift? Strength?
Did you lose any characteristics by doing this?
Can we see this research?
p911
06/02/2010 11:30 PM
Interesting! At this point, I have no idea what "Gun-Smash" refers to. (I just now noticed the reference in small print to moorec74 - perhaps it is there).
Did you actually have equipment to modify, or is the project purely theoretical so far? I hope the former - I'm an extreme believer in 'learn by doing'.
Good Answers: 119
06/03/2010 8:57 AM
Wow, I hope there's a lot more to this research on my beloved Hook than just providing higher horsepower from new engines and increased lift from redesigned blades!!!!
What is being looked at in terms of beefing up the 5 transmissions and the drive shafting between the combining transmission and the forward transmission to handle massively increased torque?
What is being done do ensure the airframe loading between the hooks and the rotor heads can handle the increased loading and vibration?
Keep in mind that the foremost thought for heavy lift helicopters is not horsepower and lift, but TORQUE!!
Did you look at the research behind this Chinook variation, with its 110" stretched fuselage, variable pitch wing and 4 bladed rotor heads.
Winged Chinook
Frankly, what you're proposing would scare the pee outta me. Nobody I know who has dealt with helicopters likes the idea of linked airframes with independent control and power systems. If one has a problem and has to dump the load the other crew is almost guaranteed to die.
As a non-practical exercise though, it sounds like fun.
Hooker
Good Answers: 97
06/04/2010 2:52 AM
Hooker,
Just some OT ramblings....
I will never cease to be amazed at what is asked of the Helo guys.
I spent about three years watching the guys in the SH-3's hanging off the four quarters of the flight deck, day in, day out, waiting to pick aircrew in case they went in. Plus the anti-sub duty.
I remember the "tweets" at intermediate maintenance constantly "upgrading" the ASE systems due to "glitches".
I remember being aft on the deck and watching a copilot give the "figure eight" as the pilot fought the craft away from the ship and into the cold North Atlantic inverted. We waited and waited until all four crew popped to the surface and were rescued.
Later we were told it was a "glitch" in the ASE.
God bless the Helo guys.
By the way, the article did not mention if they had to return tied together, with all that rig underneath.
CRTL-Z
Good Answers: 119
06/04/2010 10:14 AM
Hey Unred,
I can't speak for anybody else but most of the guys I worked with didn't have to be "asked" to get into some great adventures using helicopters. What helped when I was in was that we were basically writing the book on military helicopter use so we had pretty much free reign to try stuff.
Nowadays, a lot of what we learned back then is now doctrine, which stifles innovation somewhat. I would guess that the current crop of helicopter crews are still capable of getting into all kinds of trouble but they certainly don't have the freedom we did back in the '60's and '70's.
I'm glad I wasn't in Navy aviation. We landed a Hook on a carrier once in flat seas. I can't imagine doing that regularly on a wildly pitching deck.
Hooker
06/04/2010 9:26 AM
Some of the stuff they come up with and actually try is unbelievable.
When in a time of war, in your head deep in $h!#, and you still have to get a job done, and your only way out is to red line any peice of equipment you have. They do.
Good Answers: 119
06/04/2010 10:01 AM
"When in time of war,..."
Been there, done that. Your comment sparked my remaining brain cell.
During Vietnam, my unit got a call for help from an armored Cav unit that had an APC (armored personnel carrier) stuck in the mud of a rice paddy. We had done this before so we sent a Hook to pull it out. To make a long story short, the APC was too deeply mired for one Hook to help, so we sent a second. The single Hook had taken the engine torque meters to red line without budging the thing.
This was an effort we'd never tried before but nobody thought it was a big deal, and the second Hook was quickly rigged up to the APC. Without thinking, both pilots commenced to pull together with the direction of flight of both Chinooks parallel to the direction the APC was pointed. Since everybody's attention was directed at the APC, disaster was narrowly averted when an alert crewmember notified the pilots that the Hooks were about to mesh blades because the cross vector of the pull was bringing the two helicopters together.
A quick re-evaluation of the effort resulted in the decision to alter the helicopters' headings about 20 degrees to the right and left of the desired pull direction. The APC was soon out of the mud and we all went home for a beer, or ten.
Hooker
06/04/2010 10:48 AM
and then you went along as business as usually, with that event lost to history........until now.
thanks for sharing
Good Answers: 179
06/05/2010 10:04 AM
Linked-together chithooks? Very scary stuff for the air crews indeed! "They were Expendable" comes to mind....
Signed,
A forner US Army Ranger and Mil chopper passenger many many times over (that I wish to remember and count).
CaptMoosie
CaptMoosie (1); dkwarner (1); Hooker (3); phoenix911 (4); Snaketails (1); Unredundant (1)
