Ever since I built my first soda can solar heater
three years ago, I've received plenty of input on how to improve the
design for better heat output. For that reason, I never hooked up the
first one – in fact, I gave it away to a friend – and set about
building a bigger, better version, suffering through three cold winters
in the garage.
I started out by looking for a sliding glass door, which
I found locally for free, then took all my measurements from that.
Minus space for the insulation, the sliding glass door allowed for 180
cans (versus 50 for the first version), which took a while to
accumulate, given that I've sworn off soda the last few years.
Aside from the addition of the insulation, the build went pretty
much the same as the last one: Build box, seal it up, drill holes in
cans, stack them, paint them, drill inlet and outlet, use shop-vac
parts to funnel air in and out. Because this box turned out much
heavier than the last, PVC pipe wouldn't do for a stand, so I popped
some Tractor Supply wheels on it and built a hinged stand from 2×4s.
Read the Whole Article
