While Singapore and Malta are taking steps toward preventing
future water shortages, there are a few technologies that may be on the
forefront of saving and recycling wastewater for a variety of applications.
An Eye on the
Manufacturers
In one day, a semiconductor chip-making plant can use the
same amount of water that a medium-sized city would use. Environmental
Metrology Corporation has developed an electrochemical system that boasts
reduction of water use by as much as half. This technology will help chipmakers
verify when contaminants have been fully removed from silicon wafers.
The system operates using both hardware and software to
sense when the wafer has been adequately rinsed through electrical impedance.
This technology isn't just good for the water preservation, but also for
companies who save money by having less water waste to process. A typical chip-making
plant can use anywhere between 2 -to-4 million gallons of water a day due to
the "more is better than less" philosophy when rinsing wafers.
So Crazy it Just
Might Work
Atmospheric Vortex Engine
This energy-harnessing scheme relies on hurricane power,
which releases enough mechanical energy to power Earth for several years. Louis
Michaud, a Canadian engineer, plans on creating an Atmospheric Vortex Engine, a
large cylindrical room filled with warm air and steam. Theoretically, once the
whirlwind is created, the vortex should become stable and drive a turbine. This
system is expected to produce 200 megawatts per 200-meter-diameter machine.
Urine Powered Cars
Gerardine Botte, a chemical engineer at Ohio University, has
created a technology that effectively converts urine to hydrogen for fuel-cell
powered cars. Urea, a component of urine, has four hydrogen atoms per one
molecule. These hydrogen bonds are much easier to break than water. Water is
usually used as the source of hydrogen in fuel cells. However, water requires
1.23V to split the molecules, whereas urea only needs .37V.
Studying Mangroves
Mangroves, a type of tree that thrives in saline habitats,
trap 97% of the salt in their roots. The salt that does not get trapped in the
root system is excreted by the leaves and eventually blown off in the wind as
salt crystals. Humans believe that the best desalination method is reverse
osmosis, which requires high energy and frequent changing of membranes. Don't
get your hopes up too high. Technologies derived from mangroves have not yet
eliminated the toxic brine by-product from all desalination processes.
Are these crazy schemes foolish ventures or innovative
ideas?
Resources
infoTECH
– Tech Firms Have an Eye on Water-Saving System
IEEE
Spectrum – Powered by Crazy
