Speaking of Precision Blog
Previous in Blog: One EV That I’m Excited About   Next in Blog: Four Drilling Symtpoms That Say "Check Run-Out"
2 comments
The Chatter About Chatter
Posted April 15, 2011 8:30 AM by Milo
Chatter costs money when you reduce the productivity of the machine by slowing it down to make the vibration go away.
Chatter.
Conventional wisdom states that there are two kinds of chatter: Forced and Self-Induced. Some shop guys like to think its caused by the material.
Forced chatter is a result of alternating cutting forces that result from
1) Interrupted cuts (milling);
2) Machine vibrations such as out of balance motors, spindles, gear or shaft irregularities, bad couplings or bearings, (Loose motor mounts and weakened or stretched) couplings;
3) Load on tool / workpiece changing as a result of acceleration or decceleration;
4) Vibrations being transmitted through the machine and foundation from other equipment.
If forced vibration is what you have, confirming the integrity of the machine tool and its power train is a critical first step. Reducing the feed per revolution is one way to determine if it is the variation in the cutting process that is forcing the vibration. Changing the SFM or RPM's by at least 25% is also something to try (increase or decrease!)
Self-excited chatter is induced by a change in the cutting forces themselves, and is where I place the chatter that may be caused by the material. Self-excited vibrations can be distinguished from forced vibrations in the machining system because self-excited vibrations stop when the cutting does. Forced vibrations are not dependent on the cutting process, and so continue even when the tool is not in the cut. Self-excited chatter can be caused by:
1) Change in forces needed to cut caused by differences in the material - Material characteristics (such as workhardening or microstructural differences) that result in variation in chip thickness.
2) Unstable built-up edge (BUE) forming then breaking off causing variation in the cutting forces.
3) Insufficient stiffness of the workpiece, spindle, tool and tool holding (think deflection and too much length).
To eliminate self-excited chatter, decrease the length of the tool in the cut, shorten the tool holder, or substitute more rigid tooling and support materials (a carbide boring bar deflects less and can make three or more times heavier a cut than one made of steel for example).
Still think it's the material? Here's my Metallurgist's tip: Look and see if you have changing build up edge conditions on the tool that exhibits chatter. If the self-excited chatter is due to material such as an unstable built-up edge (BUE) forming, try increasing the RPMs / SFM. Spindle speeds that are too slow allow workpiece material to weld to the tool edge (pressure weld) and build up. This creates higher forces until it sloughs off. Then forces go back to normal, and build up again until …
Higher RPMs help to keep BUE stable and under control. And they allow you to run faster cycle times, contributing to profits.
Bottom line: Chatter doesn't always mean you need to slow down.
Photo credit.
Re: The Chatter About Chatter
04/16/2011 1:27 AM
I always increase speeds and feeds when chatter started, seemed to smooth it all out contrary to other thinking. That was many many many years ago...
04/16/2011 3:51 AM
Chatter is caused by the various harmonic frequencies of the tool, tool holder, material being machined and machine base. Varying the speed up or down will get it to a range where those harmonics don't exist.
Nothing exceeds like excess.
Register to Reply 2 comments
