E&E Exchange Blog
E&E Exchange
Previous in Blog: Cleaner, Cheaper “Liquid Coal”   Next in Blog: "Open Happiness" from a Renewable Bottle
5 comments
Making Thermoelectrics in a Microwave
Posted January 25, 2012 1:15 PM by cheme_wordsmithy
The microwave oven - used to nuke leftovers and create breakthrough thermoelectric materials. Wait… what?
Researchers at Rensselaer Polytechnic Institute (RPI) have developed a process to create new thermoelectric materials using nanoscale sulfur and an everyday microwave oven. Ganpati Ramanath, the RPI professor who led the study, believes the new process could open the door to a completely new age of cooling and heat capture technology.
The Science
Thermoelectrics are materials that capture and convert heat to electricity, and (vice versa). On an atomic level, this thermoelectric effect occurs due to the diffusion of charge carriers in a substance induced by a temperature gradient. In other words, charges move through a thermoelectric material from the hot side to the cold side, generating an electric voltage.
The diagram to the right describes the layout of a thermoelectric module acting as a generator. N-type and P-type thermoelectric materials are sandwiched between layers of a ceramic substrate, arranged in a way that determines the direction of current flow in the device. Applied heat causes charges to flow through the materials, creating a current which flows from the conductive materials into wires to generate electricity. Here is what they look like on the outside:
Where Thermoelectrics Stand Today
What makes thermoelectrics so intriguing is that they provide a means to capture heat generated from inefficient processes that would otherwise go to waste. For example, thermoelectrics are used in the form of automotive thermoelectric generators (ATEGs, see right image. Image Credit: thinkprogress.org) in cars to increase fuel economy by capturing a portion of the energy sent to the car's exhaust (40% of an internal combustion engine's total produced energy). But they could be used in everything from power generation to refrigeration and microprocessor cooling.
The problem with thermoelectrics is that it was impossible for them have both low cost and high efficiency, making them suitable only for niche applications. One of the reasons is that, up until now, researchers have only been able to make large quantities of high efficiency p-type materials, but quality materials of both types are needed to make an efficient thermoelectric device. RPI says that its new process has overcome these shortcomings.
A Bright Future
RPI's new process is driven by the idea of doping nanostructured thermoelectric materials with tiny amounts of sulfur. Cooking the doped solution in a commercial microwave for a few minutes results in the formation of a powder of the desired material. The powder (made of hexagonal bismuth telluride nanoplates, seen left - Image Credit: Technology Review) can then be made into usable pellets by applying heat and pressure.
This process produces about 15 grams of material in two to three minutes using only one small microwave oven. The process can be easily scaled to produce larger quantities with industrial-sized microwave ovens. Professor Ramanath gives his own explanation of the process in this video.
The ability to tweak the properties of the materials on a nanoscale level is what has unlocked the ability to produce high efficiency thermoelectrics of both n- and p-type. This has the potential to start a new generation of thermoelectrics.
"This is not a one-off discovery. Rather, we have developed and demonstrated a new way to create a whole new class of doped thermoelectric materials with superior properties," says Ramanath. "Our findings truly hold the potential to transform the technology landscape of refrigeration and make a real impact on our lives."
I think the implications of this new development are really exciting. Part of the problem with current technologies like IC engines, generators, and refrigerators is that we are reaching the limits of efficiency gains. But thermoelectric materials provide a means to make these devices better. For cooling applications, thermoelectrics could both reduce footprint and replace the need for potentially harmful refrigerant fluids. In terms of heat transfer, they could transform the design of everything from cars to power plants.
Perhaps it will even make oddball consumer products like this a little more practical. Maybe…
Sources:
RPI News
Technology Review - New Process Makes Heat-Harvesting Materials Cheaply
Re: Making Thermoelectrics in a Microwave
01/25/2012 1:24 PM
My wife used to flip out when I used her oven to cure black wrinkle paint.
This would really send her into orbit!
01/26/2012 10:35 AM
Yeah, women are funny like that --You should have seen my wife when I used her Cuisinart to wash my hunting socks.You know, the ones with "doe in heat" urine on them?
01/25/2012 1:45 PM
There are enenficies. but capturing the ineffective energy (heat).
What about passive, such as what an RFID tag has where it uses a coil to capture the frequency, generates AC to send a signal.
01/26/2012 1:32 AM
There also good for making thermoplastic. Microwaves can be used effectively for a variety of industrial purposes. If only they could cook food. Can you imagine?
Good Answers: 19
01/26/2012 7:45 AM
What is the recipe for this material? sulfur, bismuth, tellurium...? ?
What proportions ?
I don't seem to have a nanomaterials setting and I am guessing ... using the popcorn settings?
There's a theory stating if anybody discovers exactly what the Universe is for & why it is here, it will instantly disappear & be replaced by something even more bizarre & inexplicable. There's another theory stating this has already happened.D Adams
Geode Hunter (1); HiTekRedNek (1); JE in Chicago (1); lyn (1); phoenix911 (1)
