Hemmings Motor News Blog Blog
Previous in Blog: Bring Back Shop Class   Next in Blog: Chevelle, Corvette Cloners Busted
Project HMX – Fine-Tuning the Stroker
Posted August 02, 2012 9:00 AM by dstrohl
I knew even before I'd started this project that the stock Chrysler EFI system from the 4.0L HO Jeep six-cylinder would need some tweaking to work with my 4.6L stroked six. Increasing displacement meant I'd need more fuel. More fuel meant I'd need more air, and more of both meant I'd need a way to convince the stock computer to play along, or else driveability, economy and power would all three suffer.
First, I started with 24 lb/hr blue-top Ford 5.0L V-8 fuel injectors from FiveOMotorsport. Some stroker builders have reported that they've been able to get their stock 19 lb/hr injectors to work, but the math shows that the stock injectors would be at their maximum duty cycle supplying a stroker, so I went with the Ford injectors to be on the safe side. While the injectors worked with the stock Jeep fuel pressure regulator (fixed at about 37 PSI), I still encountered lean-outs with that setup, so I decided it was time to step up the pressure to the 49 PSI the Ford injectors were meant to run at.
Read the Whole Article
Re: Project HMX – Fine-Tuning the Stroker
08/02/2012 8:22 PM
Finally a half way decent write up relating to how someone modified a modern vehicle engine in one form or fashion.
As with any engine if it got bigger the fuel and air supply systems have to get proportionally larger as well.
As shown here with electronic control systems modifying the computer program is not always practical but with a fair understanding of what the control system is looking at and trying to adjust to/for it is entirely possible to modify the sensors signals to change the running parameters to what you want or need opposed to what the original factory programmers thought was best.
