Residential and commercial buildings are going through an evolutionary period driven by megatrends moving buildings to higher efficiencies, lower emissions/losses, cleaner air and quieter sound levels. These have driven hvac equipment manufacturers and system designers to newer, quieter, more compact, more efficient and newer technologies to keep step with the changing requirements.
But change brings opportunity for those nimble and open minded to look for these opportunities and I've got to believe these opportunists are excited about the latest trends in housing (and to a lesser degree commercial buildings):
- The move to prefabricated buildings
- The use of less spacing, downsizing
This was evident in yesterday's announcement by New York's mayor Michael Bloomberg of the winning design for the 300-square-foot "micro apartments" that will make up 55 unit "micro buildings" to be built next year and occupied the year after.
My Micro NY will be the first multi-family building in Manhattan to use modular construction, with the modules said to be safer and more efficient since the plumbing, electrical, and building development is done in a controlled, indoor environment.
Micro apartments will make use of movable furniture as well as walls and partitions to repurpose the areas for different activities throughout the day and night.
The very small and varying magnitude of the heating and cooling loads combined with walls that aren't always in the same place will force system designers to rethink current heating and cooling systems. Locations such as diffusers and grills may not always be "available" for that function. Air flow patterns will change through the day if existing equipment and design practices are followed.
New HVAC equipment will need to be even smaller (in physical size but also in capacity), even quieter since proximity to occupants will be an issue, more flexible and precise in operation. Perhaps this is one of the reasons behind the trend toward pre-manufactured buildings where hvac equipment can be pre-installed in clean controlled environments.
To read more click New York City's First 'Micro Apartments
Editors Note: CR4 would like to thank Larry Butz of GEA Consulting, for contributing this blog entry.
