Hemmings Motor News Blog Blog
Previous in Blog: Take the Last Train to Carlisle: Monkeemobile Number One Heads to GM Nationals   Next in Blog: Avantis to Descend on Gainesville, Florida, for Winterfest
5 comments
Tech 101- Brake Fluids. What’s Different About Them and Why Should you Care?
Posted December 12, 2013 8:00 AM by dstrohl
Pathfinder Tags: brake fluid brakes Hydraulic
Recent findings conducted by the National Car Care Council revealed that 86 percent of the cars they randomly checked during state vehicle inspections, had at least one item that would cause the car to fail. Fifteen percent of these cars had low, contaminated or worn-out brake fluid. To put this another way, more than one in every 10 cars you are traveling with along city streets and highways has the potential of a brake failure due to brake fluid issues.
Brake fluid is the key ingredient in any hydraulic braking system. The fluid is not only subjected to hundreds of pounds of pressure on many occasions during your drive, it is also a lubricant for the rubber components in your master cylinder, wheel cylinders, calipers and hoses. Additionally, brake fluid has corrosion inhibitors that keep the bores of hydraulic cylinders from rusting and pitting.
Read the rest of this entry on Hemmings.
Re: Tech 101- Brake Fluids. What’s Different About Them and Why Should you Care?
12/12/2013 8:16 AM
What's up with the link? (Apparently no URL!)
12/12/2013 12:52 PM
12/12/2013 6:42 PM
Cheers. Found it anyway, but how can someone post something like that without checking their links? And not, after all this time, have checked for comments? Reflects badly on both Hemmings and Globalspec, IMHO.
12/12/2013 9:04 AM
The fluid is not only subjected to hundreds of pounds of pressure on many occasions...
AAAAHHHHHHHHHH!!!!!!!! That drives me nuts. It's pounds per square inch of pressure, not pounds of pressure. Pressure is force per unit area.
Sorry, just had to vent a few pounds of pressure.
J B
12/13/2013 4:21 PM
Every time I do that I must turn on a vent fan.
Anonymous Poster (1); JBTardis (1); JohnDG (2); SolarEagle (1)
